Looking to understand a little more about how the TRX1 operates, under the hood.
Let's say I have 5 objects in a scanlist. Then, I add one of those objects to 3 other scan lists and enable those also.
Does the scanner:
a) Scan the duplicate object 4 times as it sequentially moves through each object and scan list in order (Scanning 8 total objects)
-or-
b) De-dupe the contents of all enabled lists so that duplicated objects get the same duration of scan time as others (Scanning 5 total objects)
-or-
c) something totally different?
As you might imagine, I have one object assigned to multiple scan lists that I often will enable together. I'm curious if this approach will 'slow down' the scanner at all.
Thanks!
Does the scanner:
-or-
-or-
Thanks!
