object reference not set to an instance of an object
frankcastle
Marshall County Indiana
That is the error message i get when trying to set up my live feed. I have relaunched scannercast several times with no luck. Here is my error log:
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
fmqnzoqo
Assembly Version: 1.0.0.0
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Any Thoughts? Thanks
richtidd
Live Audio Administrator
San Mateo, Ca
fmqnzoqo
enabled.
For example:
<configuration>
</configuration>
I know what the problem is.
You do not have a feed, therefor you can not be setting one up.
There are no feeds listed under the user name of frankcastle.
We just received your feed application this morning within the last 1.75 hrs.
We have not yet approved it.
We are processing it.
frankcastle
Yes, I realized I put the cart before the horse. I was just trying to figure out as much as I could before I jumped in with both feet. Awaiting your approval sir. Thank you!
richtidd
San Mateo, Ca
For me to approve your feed application, please answer the e-mail I sent you requesting more info.
PeterGV
K1PGV, ScannerCast author
Mont Vernon, NH
fmqnzoqo
Even though we know the REASON you got the above error, I'd like to try to fix ScannerCast so that it handles the problem a bit more gracefully.
Can you tell me the steps you went through to cause the above problem? I thought I was properly handling the case of somebody requesting their feed config information, even when they're not set-up yet as a feed provider.
Whatever info you can provide, especially a detailed list of steps that led to the above error, would be appreciated.
Thanks,
Peter
K1PGV
