OCEM Radio Maintenance personnel (OC maintains its system along with their vendor Eastern Communications) reprogrammed OCFD Fire subscribers to include direct access to Sussex County fire tgs as mentioned earlier in this thread. The Sussex patch hasn't been used for months. Tangentially, the USCG tg on OC's system is never used and coordination for water rescues uses a FIRST system tg in the Ocean City area. The Trooper tg is no longer used, and I would guess the DSP patch will eventually go away as well.
@DisasterGuy is absolutely correct in the sense that the Worcester and OC systems operate in as an interconnected countywide / wide area network and he should know. Radio personnel from both jurisdictions work together to operate the system, and as he mentioned there are centralized management facilities to enable wide area functionality. However, I will continue to push back against the idea that they are "one system". These systems were authorized and funded separately; I believe that they were commissioned at different times; the city system was designed with dense portable-in-building coverage; and the city's system did not have coverage and interference problems that plagued the county's system until some re-engineering, antenna adjustments, and additional sites were constructed in Mystic Harbor and Snow Hill. Many local and wide area systems share site infrastructure and backhaul paths but remain separate entities. The relationship between the city and county systems is probably more akin to systems like ICORRS or perhaps the city of Wilmington and the state of Delaware. It is not like Frederick or Washington counties where Frederick (city) and Hagerstown host their local departments on a countywide system; nor is it like Maryland where some counties use FIRST as their communications system - although counties can fund local enhancements for their operations.
As for scanner users, Ocean City is now a site in the Worcester system if you download the system again. The Ocean City system has been removed from the RRDB. I recognize the logic behind the change, but scanner users need to be aware that nothing changes as far as where certain tgs can be received.
