Ocean County NJ Frequencies
patsboys3
Toms River, NJ
For some reason Ocean County frequencies aren't workiing, any suggestions, uploaded with win96 and still nothing. Using a Radio Shack Pro96 Scanner.
patsboys3
Toms River, NJ
All of these... LOL
505.0000 12.5 380
System ID List
System ID Connect Tone
5C3F 116.13
Latest News Update Posted on 2009-09-23 20:44:53
The following frequencies were granted by the FCC on September 3rd:
476.31250
476.38750
476.43750
476.48750
476.53750
476.58750
476.71250
476.73750
476.93750
477.26250
478.46250
478.61250
Click Here to Display All Past News Updates (3 Total)
Misc System Information
See the Ocean County page for conventional frequencies.
For new Uniden scanners that require a lower & upper channel in the base & offset table:
Channel Low Channel High
505.0000 509.7375
System Frequencies
Red (c) are primary control channels | Blue (a) are alternate control channels | Site Map(s): FCC Callsigns RR Locations
Site Hex Name Freqs
001 1 Simulcast 506.61250 506.66250 506.68750c 506.78750 506.81250 506.83750c 508.06250 508.08750
508.13750 508.16250 508.43750c
elias1988
Station 44 Member
Seaside Heights,NJ
Are the frequencies set for MO or Motorola and did you upload any talkgroups? also is the custom frequency table set?
elias1988
Station 44 Member
Seaside Heights,NJ
Ok,the frequencies need to stay on MO.try programming in the frequency table by hand.heres how to do it: press PGM>TRUNK>FUNC>3 should say 3600 CC Mode this needs to be set to table. press enter,next press FUNC then 2 and it will say base freq offset and step. put in 505.00000 for the base frequency and then set the offset to 380 and finally set the step to 12.5
patsboys3
Toms River, NJ
Ok did that let's see what happens, so far nothing, should I maybe reset my scanner. I only have ocean county and manchester in there right now, so maybe rebooting the scanner might help.
patsboys3
Toms River, NJ
Ok still nothing, used to always get it, now nothing, maybe I will try programming oc in by hand instead of using win96, I will put in into a different bank and see what happens.
Ocean ?
Someone told me brick,and most ocean county systems are P25 but are Encrypted.Are we all up the creek soon?Is my $500 scanner a soon to be door wedge?
cassidy1190
Belmar, NJ
This may sound strange, but on my pro2096, I had to program all the frequencies starting on the 5th channel in the bank (channel 405 for example) for it to trunk properly. Don't ask, all I know is that it didn't work before and now it does.
DJ88
Brick Twp., New Jersey
Did you program the 400 MHz frequencies as part of the trunk system? If so, get rid of them. They're not part of the trunk system. They are conventional frequencies that will eventually be used as a back up to the trunk systerm. The trunk system periodically experiences severe interference from what I believe is a digital television station somewhere and when the 400 MHz frequency conventional system is up and running it will be used when this interference occurs. If you want to program them, program them in a separate bank as conventional (non trunked).
elias1988
Station 44 Member
Seaside Heights,NJ
The interference is from tv stations in the CT area. the one is in Waterbury that does the most damage.
elias1988
Station 44 Member
Seaside Heights,NJ
Ok i thought they were going to be used for trunking,i forgot theres conventional frequencies mixed in with the trunking licenses.
