Batteries 1 and 3 are toast...
Ok just pulled batteries out of 436. Then I just thought: Since its not really recommended to charge batteries in scanner and for the fact that if you want to listen to it for more then 10 hours with 14 hours off to charge you will need to charge batteries externally as we have talked about. Then I realized it's 3 batteries and you have to charge in evens. So what do when having to charge 3? Rotate out one extra battery? With 4th battery and no down time seems you will need 8 batteries and a complicated system to rotate batteries so each one gets used the same. Or do you just have 2 batteries that aren't as good that you throw it as sacrifices?
Sent from my SCH-I545 using Tapatalk
First results of an analyze and refresh on my new Maha charger with some 2500mah batteries that I was getting ready to trash due to having charging errors on my energizer charger.
Battery 1. 127 Mah, 16 mins, 1.41 volts
Battery 2. 2333 mah, 156 mins, 1.43 volts
Battery 3. 675 mah, 46 mins, 1.31 volts.
Not sure really how to interpret the data
If I were to invest in say 12 more batteries would you go with the enveloop xx or the new duracell 2400, energizer 2500 or the power ex or power ex imedion? Which is more bang for the buck. I have been fairly satisfied with energizer but I have those light angel motion detection lights and they seem to only last maybe a week or less of use.
lawman210 - some notes on your new charger...
To do an actual capacity test, you fully charge the battery and then *discharge* at the industry standard C/10 rate until the Maha stops and displays the current discharged into the internal dummy load. It will typically stop at 0.9v, so you don't need to worry about this test killing the battery by draining it completely.
Many make the mistake of trying to determine capacity by how much was used during charging. It is the *discharge* test that will tell you the capacity.
To see if a Sanyo Eneloop's capacity is actually at it's 2000mah rating -- Let the Maha charge it fully, and then do a discharge at C/10, or 200ma and let it do it's thing. You can do 4 at a time obviously, and it will take some time. This is how battery manufacturers rate their batteries at the C/10 rate. Accordingly, for a 2400mah battery, you would fully charge, and then discharge at 240ma. (or as close as the maha would allow - 200 or 300ma discharge is close enough).
Battery fanatics that purchase large amounts of batteries at a time even prefer to keep their scanner batteries in "packs", with capacities very close to each other and the Maha makes this easy.
You can also use the Maha's capacity check to see how well other chargers charge the battery! Fully charge in the other charger. Pull them and place them in the Maha for a standard C/10 discharge and compare the capacity to what the Maha is capable of charging the battery to previously.
There is no point in trying to revive decrepid old abused batteries. While the Maha will do it's best to charge ancient batteries, you may never get the full capacity they once had. Once a battery only delivers about 80% of it's capacity (as checked with the discharge test above!), recycle them and get new ones.
Trying to keep abused "zombie" batteries in use was a fad from the 80's.
Eneloops - make sure you are getting relatively new stock, not the originals from a decade ago. These new ones have a small golden crown on the wrapping. In regards to the Eneloop 2500's, yes they are good, but there is no free lunch, as they have less cycle capability than the standard 2000mah eneloops. So you have to choose which is more important to you.
Don't get too hung up on battery marketing - quality cells like Eneloop, Imedions, and the like will quickly prove themselves. Of course, avoid online deals too good to be true or you may end up with counterfeits - another thing the Maha can usually quickly identify.
Remember that the Maha will tell you the internal IMPEDANCE of a cell as described earlier. Maha checks this, and will kick out batteries that are abused, too old, etc that have high resistance (about >2.2 initial impedance check). Unlike other chargers that may just kick them out, Maha gives you an actual value - but it does so only once upon insertion of the battery, and thereafter reads the voltage. This feature will also quickly identify batteries that get rave reviews in online forums, only to be quickly identified as bunk by the Maha.
You chose a great unit.
