ProScan: Odd ProScan Webserver Behavior
Jake68111
Morris, IL. (Grundy County)
All setup and really like the software but I'm getting janky websever results.
Is this normal? Specifically the webpage auto reloading on its own intermittently and even after giving the server time to sync with the 24 second delay, it never really syncing.
ProScan
Software Provider
Ontario, Calif.
Thanks for the report. I had a few reports in this area. With your video, I have a little more info. If you will email me, I will send out test files to narrow down the problem and you will get the fix sooner then when the next release is.
ProScan
eaf1956
Evansville, IN
I got it working once by clearing the web server folder but it came back. Just keeps reloading the page especially when you try to turn on the audio.
Sent from my SM-N960U using Tapatalk
Jake68111
ProScan
Email has been sent.
I saw, through browsing, your post on clearing the web server folder. I did so too even though it wasn't set up. Came up with the same result.
Jake68111
Hey Bob, for some reason or another I can’t reply to your email via my phone. I’m just now seeing the email and might have a chance to get at it tonight but if not tonight, it’ll be early tomorrow afternoon. Sorry for any confusion or delay.
ProScan
Software Provider
Ontario, Calif.
Contact me via email on any testing. That link I sent is no longer the same test file. I will give you the new test file link via email.
WX4JCW
Stow, Ohio
I had some issues last night, I had Proscan freeze using the web server, also the virtual scanner display froze but the audio still worked, rebooting fixed it, but after a time it came back
eaf1956
Evansville, IN
Did you by chance just close the web server client?
WX4JCW
Stow, Ohio
No I didn’t, I know I got 10 people on, and at some point I got an overload error
Sent from my iPhone using Tapatalk Pro
eaf1956
Evansville, IN
Mine would LOCK UP Proscan sometimes when I turned off the phone or shut down looking at the web server. Hasn't done it lately since Bob worked on the Reload issue.
bravada
Lunenburg, Nova Scotia CANADA
Another question relating to Proscan and Web Server. I’ve had mine running this week and not sure what I need to adjust with the settings but display and audio from the scanner is really out of sync. What are you finding for optimum settings in this regard? Other than this I am finding Proscan awesome to use. With a bit of a learning curve for me I’ve got the RSOIP things working awesome with the BCD536HP. Thanks in advance for any help here.
eaf1956
Evansville, IN
Audio delay is usually about 24 sec on my system. There is a metadata delay setting on the receive device.
