Off Center Fed Yagi?
gregory21greg
If you can have an off center fed dipole and since a Yagi is just a dipole with passive elements to direct the signal then could you feed a Yagi off center and get the same resonance that a normal ocf dipole has but with forward gain?
prcguy
It should not matter how you excite the driven element of a Yagi, do it from the center, the end, offset or anywhere in between if its adequately decoupled from the feedline.
prcguy
majoco
Stirrer
New Zealand
IMHO the whole idea of an OCFD is that it covers a wider range of frequencies even to the point of being "untuned". Now for a yagi to work right all the dimensions of element length and spacing are frequency dependant, so what frequency would you use?
IMHO you'd be better off with Log-periodic array.
