Off/On Duty Status
GTO_04
Noblesville, IN
What is the difference between the Off and On Duty Status on the G5? I have been unable to tell the difference so far.
GTO_04
ffexpCP
wizard of odd
Michigan
Usually used for call-backs of shift workers. Off duty tone will always alert. On-duty only alerts when pager is selected to on'duty. The G5 can automatically set duty status by time (and maybe day, I can't remember). It is also a manually set option.
Personally, I have my station tone set as on-duty and all-call for off-duty. My pager's on-duty schedule automatically turns off at night so I don't get alerted for minor calls but still want to know about bigger ones. (I'm contractually obligated to not work outside employment 8 hours before reporting to my full time job)
I'm still trying to figure out how to configure on/off duty status for p25 talkgroups. Any ideas? So far it silences everything.
krokus
Southeastern Michigan
We used the selector knob to make an off duty position, and only have the department all call, and county wide alert in that position.
Sent via Tapatalk
W8VI
Batavia, Ohio
I accidentally set the Duty Status settings to Auto and it muted the speaker during Off Duty hours. Everything worked except for no sound and the display showed a small speaker with a hash mark.
If you select from the PPS software D / 7 then Duty Status Settings and chose Auto you can select what hours and days the G4/G5 will mute the speaker. It is set for 0900 to 1800 and it goes to Mute from 1801 to 0900. It nearly drove me crazy trying to find out how to turn off the Mute.
Duty Status: When Auto mode is selected the speaker is muted during those selected off duty hours.
ffexpCP
wizard of odd
Michigan
Sent via Tapatalk
How did you do that? I've been trying to set up duty status by knob position like a minitor, but haven't figured it out yet.
krokus
Our off duty only alerts for our deparment's all call, and the county weather alert. We used one position to mirror the on duty alerts, but utilizes vibrate instead of tone, and push to listen.
Sent via Tapatalk
