Off the wall PL/DPL tones?
rpgaun
Sun City, Az
This question is a bit off the wall as I would imagine not many folks listen to the radio system in question (if any) so here it goes. Does anyone have the PL/DPL tones for S.A.F.E. Management that provides security at University of Phoenix Stadium? I found their license in the FCC data base so I have the frequencies and possible channel assignments.
krokus
Southeastern Michigan
Did you check the database? It has that info, more often than not.
Sent via Tapatalk
rpgaun
Sun City, Az
Sent via Tapatalk
There is nothing listed in the data base for Stadium Security. Southwest Ambulance uses their "events" Frequency and the PD coverage uses G Deck TGs. Security is on Business Band thus the need for the PL/DPL.
ko6jw_2
Santa Ynez, CA
Does your scanner have a PL search function? Listen to both the input and output frequencies. Some systems have a different tone for accessing a repeater and the repeater has a separate PL for decode.
KB7MIB
Peoria, AZ.
What is the emission designator for their frequencies? IIRC, having checked the listings in the SWFD-10 for the stadium, I heard MotoTrbo digital noise. CTCSS/DCS isn't used in MotoTrbo.
There's a lot of MotoTrbo in the 451-470 MHz as well as the 935-940 MHz business/industrial bands. The only analog FM activity in 935-940 MHz that I've heard is SoCal Edison's trunked system, which has a site on the White Tank Mtns.
rpgaun
Sun City, Az
I do not believe they are on a trunking system. Here are the frequencies listed on the license;
461.95000
466.95000
462.02500
464.32500
464.37500
467.02500
469.32500
469.37500
469.67500
469.80000
469.82500
I have programed these in the scanner with the PL Search active.
ecps92
Taxachusetts
Correct, according to the FCC, Non-Trunk and Analog (Narrowband)
However only 461.9500 is a Repeater, all others are simplex
461.95000
466.95000
462.02500
464.32500
464.37500
467.02500
469.32500
469.37500
469.67500
469.80000
469.82500
