UPMan said:<shameless plug>Or Uniden sells suitable accessory speakers</shameless plug>
Is this a new product? It says back ordered. How about a version with a built in amplifier for the 330 and 396?
oregontreehugger said:A suggestion for Uniden: since the remote head is going to need a power source, how about the option of plugging it in OR running it on a couple of internal AA batteries that can be changed by the user?
That would be one less wire to run for mobile folks. Especially since you're already going to have power to the scanner, antenna to the scanner, audio most likely to an external speaker, and the cord from the remote head to the scanner.
DaveIN said:It would use several milliamps per hour to keep a large graphical display with multiple lites on for any length of time (don't forget the backlit keypad). I'll bet that's why it mentions external power supply.
UPMan said:x and y dimensions are the same as the BCD996T/BCT15. z (depth) will be about 2 inches and the power/data jacks are on the back. There will be a jack for firmware updates that faces downward, but this is a seldom-connected jack.
wm8s said:There is a command that will cause the 996 to emulate a power-off, but it doesn't actually power the radio off.
(e.g., how the remote will detect changes to the radio's volume made from the radio's front-panel volume control). Lots of polling, I guess...
b52hbuff said:All well and good, but does it run linux?![]()
jpjohn said:1. I am in no way familiar with FCC rules, but why does this require any FCC approvals or input as it is not a radio - just an option to add to radio's already released. UPMan mentions FCC approval in an earlier posting.
jpjohn said:2. Since it doesn't sound like you need to remove the current face, would you still be able to control everything from the original face as well as the remote head? This would allow somewhat like a dual control head.
jpjohn said:3. Just an observation - location of power and data jacks are mentioned as being on the back. Please look at option to allow for mounting in another location, perhaps bottom. If you mount this head with velcro you most likely would mount flat on back. Just food for thought. I know each individual will have different requirements, so maybe have dual jacks such as bottom and back to allow for different mounting locations????
