1080iAddict said:
As it should. Tone out should require a dedicated feed or you miss the tone out, and what good is that?
IYou want dedicated TO? But a Minitor pager (which will do more than one set of tones - especially the IIIs and IVs that will do up to 7 calls). You want dedicated SAME? Buy a WX receiver. Both will add up to less than the cost of adding the second RX to a scanner. More over, you can use all three at the same time. Even your second RX won't allow that!
Joe M.
I use a seperate radio for each function, but where are you getting your minitors for less than half the cost of the 396? Just bought a batch of six, cost of 325 each, and that's one frequency only. no stored voice.
I've always valued seperate radios, can have all going at once, not worrying about what you might be missing. When I weather spot, I've almost run out of room to clip all the handhelds, mobile is on, and usually in contact with the wife via nextel while she eyeballs the doppler.
john
