Official PRO-96 Discussion Thread
rescue161
KE4FHH
Hubert, NC
Any word on whether there will be an upgrade that will allow monitoring of 380 MHz systems?
Shoot me square in the head if this has already been covered, but I searched...
mikey60
Oakland County Michigan
Not likely since those frequencies are not in the official list (given to the FCC) of supported frequencies for the radio.
Mike
Pro-96 reception help
I have had My pro-96 for about a year and when I first got it it had great reception that was very clear and no static. Now even when I slyghtly cover the antenna it loses the reception completley and some channels I have to move the scanner it a perfect place til I hear it then I have to hold it there and its still statiky! :x Could someone help please. By the way I did just get a new RS 800 antenna. :lol:
xusmarine1979
Louisville, Ohio
I'd recomend looking at the antenna connection on the inside, but they have that sheild thing on there, you may need to touch it up with a sodier iron. Is it on a certain band?
I dont think its the antenna cause on other channels it works fine. I am mostly monitering 155.1900 - 155.7900
rescue161
KE4FHH
Hubert, NC
The radio shack antenna is geared towards 800 MHz. Try putting your original antenna back on and see if you still get the bad reception.
Voyager
Re: Pro-96 reception help
The 800 MHz antenna perforance is not as good as the stock duck on VHF High Band.
Joe M.
loumaag
Silent Key - Aug 2014
Katy, TX
Duditz511:
Based on what you describe, and not being there, consider the following:
  • New adjacent channel interference (like a new VHF paging sytem).
    A change in the TV cable in your home, maybe you have developed a leak somewhere.
    Less likely but possible, a change in FM broadcast transmission nearby, like an increase in power or a new station.
pinetree
Felton DE
If you know the freqs. you can enter them using win96 and checking the extended frequency box in the first page. I can monitor Dover AFB within 5 miles. All are in the 380 range
rescue161
KE4FHH
Hubert, NC
I can monitor/hear the frequencies, but I can't trunk track them. Are you saying that you're able to track them? What type of system is it? EDACS or Motorola?
pinetree
Felton DE
All of us who have tried cant trunk track them either using the Pro96. By removing the delay you cna usually keep up with the conversation. It is a Motorola system of a special digital type but by using the Pro 96 set in FM mode it will decode the digital.
Dave
Thanks for your replies and I will try those suggestions, I did try the stock antenna and It worked a lot worse than the 800MHz one.
But thanks!
unitcharlie
a Kentucky DB Admin...
on the road to Nonesuch, Ky...
If your radio is out of warranty and you feel comfortable changing the antenna connecter in your radio, I have found with the GRE's that they use a very fragile BNC... instead of a full contact there are two small wires some what embedded in the insulator, after a few on-off cycles with the antenna these wires are pushed into the insulation.... might think about changing to a full-contact BNC......
jbrockell
Latest CPU: F1.4
safetyobc said:
That is probably where I'll buy but just want to make sure they aren't going to go on sale first. And with Ebay you never know exactly what you are getting! I want the latest 1.3 CPU and in GREAT Condition
Just received Pro-96 for Fathers day! Checked it out and looks like the latest CPU is now 1.4.
CPU: F1.4
DSP-APP: F1.2
DSP-VOC: F1.0
Voyager
Re: Latest CPU: F1.4
CPU: F1.4
DSP-APP: F1.2
DSP-VOC: F1.0
While you are technically correct, there is no difference (to the user) between 1.3 and 1.4. No bugs were fixed. It's just a different version to accomodate different hardware. Someone with 1.4 has nothing over someone with 1.3.
I don't recall the exact release date, but when the original post you replied to was made over two months ago, 1.3 probably WAS the latest.
Joe M.
Cary
Southern CA
RE: Poor reception on some channels.
Is the problem with ALL systems in the same band (800?)? If it seems to be affect only one system, maybe they have made changes to their rado system (directional antennas, a voting system that selects repeaters closest to the mobile unit for which the traffic is intended or other performance factors).
jbrockell
Voyager said:
CPU: F1.4
DSP-APP: F1.2
DSP-VOC: F1.0
Joe M.
As a "newbie" I rather jumped to conclusions. After looking further on this site I "discovered" that. Electronics moves so quickly now that I guess even in such a short time there are changes.
John
