Chris0516
Pittsboro, North Carolina
It's a standard Windows Drag & Drop operation.
You have more then one FL. Is that correct?
Click the FL with the left mouse button and hold the left mouse button down then drag the mouse to the desired location then release the left mouse button.
Correct, More than one.
Chris0516
Chris, can you do a screen recording so he is 100% sure he's thinking if what you're attempting to do?
Not a recording, but a screenshot. Below, I would like to move the two highlighted FL. But not at the same time. So Person County is underneath Orange County, and above Randolph County. Then, moving Granville County beneath Durham-Fayettteville2, and above Greeensboro/Guilford County. I press the left mouse button continuously, to either one of them. But they don't move with the mouse.
ProScan
Software Provider
Ontario, Calif.
I see two favorites selected. You must have pressed the CTRL key while selecting the favorites. Don't do that. Just right click on a FL node and the other FL will unselect. Move one FL at a time.
Chris0516
I highlighted them both, only for the purpose of visually showing what I wanted to move. Then I mentioned that I would not move them at the same time, and where individually I wanted to specifically place them.
KC2NNS
Freehold, NJ
Hello everyone. I have ProScan installed at home with my scanner and use the ProScan Client at work to listen. A few days ago, my client at work stopped recording. Everything else for the streaming/tags/display works correctly, just no files get recorded. No configuration changes were made; at least not that I can see. I tried rebooting and even installing a fresh version of the client in a new directory. Same results - everything works but no recordings. I should note that the recordings at home are still working properly; just not the ones at work using the client.
Does anybody have anybody have thoughts on this? I'm banging my head on the wall for a few days now on this.
ProScan
Software Provider
Ontario, Calif.
Try restarting ProScan. If it still doesn't work then reboot the computer.
ProScan
Software Provider
Ontario, Calif.
Just to make sure but Is the Recorder on (Recorder button depressed.)?
Does the recording grid shows the currently recorded row in color red?
Try switching to VOX mode if in Activity mode or visa-versa.
KC2NNS
Freehold, NJ
Just to maker sure but Is the Recorder on (Recorder button depressed.)?
Thanks for the quick reply!
Recorder button is pressed. I also tried turning it off and back on again.
Recording grid shows no activity when somebody is on the channel. Only previously recorded (12/4/23) rows are shown, with no change. There's also no new files in the directory.
Tried switching to VOX just now with no change. That did just cause me to notice, however, that I'm not hearing the streaming audio either. It had previously been turned way down and I turned it up when testing VOX. So I'm sure that's somehow related to the same problem. Although the recording doesn't work when "Activity" is selected either, and the remote scanner display on the client is working properly.
ProScan
Software Provider
Ontario, Calif.
I kind of recall someone else hid a similar type of problem except not using the ProScan RSOIP client. I don't know what it is at this point.
I don't know if a Windows Update has anything to do with it. Can you advise on the OS info like the image below. Could it have happened the same time as date of installed?
ProScan
Software Provider
Ontario, Calif.
Do you hear the audio out of the computer speakers and see the audio meters move in the Audio Control - RSOIP playback side?
It shouldn't matter if the audio is turned down or up, The recording grid should show the new recordings and files should be generated.
KC2NNS
Freehold, NJ
A reboot of the server computer running ProScan fixed the issue. Not sure why/how, but it did.
My installed on date for Windows is 6/5/2023 which is way before the issue started happening. At this point I'm just happy it's working again.
Thanks for your time, and thank you for developing the program. It's great!
ProScan
Software Provider
Ontario, Calif.
Thanks for the update and compliment!
03msc
RF is RF
The Natural State
I had a similar issue with my install of ProScan on my Windows 11 Pro laptop. A series of reboots of the OS and restarts of the software and it eventually started working. I can't help as far as what was the cause but I did experience something similar regarding the recording.
ProScan
Software Provider
Ontario, Calif.
ProScan Version 22.2 Just Released!
  • Fixed - Google Maps - The internal browser wasn't showing the Info Box and therefore the nodes couldn't be updated with the new positions.
  • Fixed - Web Server - The virtual panel on the web browser wasn't showing when the view was set to Display Only.
  • Fixed - FTO Logging on the DMA models broke in version 22.0.
ProScan Website
ProScan is the most powerful and feature rich scanner software in the world !!!
NYRHKY94
Brunswick County, NC
ProScan Website
Thanks very much Bob :)
TGuelker
Retired ASE CMAT L1 MRRT
Collinsville, Illinois
IMG_4413.jpegProScan Version 22.2 Just Released!
ProScan Website
Bob is a brave and confident man releasing an update and then going on a well deserved vacation.
