DonS
Done for next release (later today).rkovalik said:I have noticed when I import a large system, WIN500 doesnt pre-calculate duplicate frequencies.
The trial version is fully-functional, and should give you audio.2nd issue, I am getting no audio with the remote client.
I set up the server and can control the scanner no problem. I enabled the controllable and enabled feature. I can connect with the client on another laptop, see the data and is controllable but there is no audio.
This is in my lan with no firewall. I left the Audio Input device as default and tried selecting my sound card. In my sound card I ensured none of the sliders were muted.
I have not registered yet as I am evaluating that the functions work prior to paying.
Maybe audio does not work without a key????
1. Do you have an audio cable connected between your scanner's headphone jack and a Mic or Line input on your sound card?
2. Do you hear the scanner's audio "live" from your PC speakers?
3. Can you "record" audio in Win500's Monitoring tab? (To test this, be sure to enable some object's REC option, then turn on both Logging and Recording in the Monitoring tab.)
4. Can you get audio from my Win500 server? (home.starrsoft.com, port 26755)
There's a little more info in this post and this one .
