Hey Don,
I am (or was) using V 1.51 and encountered an issue.
When I used the "Find Duplicate Frequencies" function, it scanned the list and found the dupes with no problem. But when I selected the "delete" button, nothing happened, the dupes remained. Because it gave me the object numbers, I just went and deleted one of them, and set the required scanlists for the other.
I also have a request. When making adjustments to my scanlists, it would be helpful if I could be able to view just the objects associated with one particular scanlist. For instance, if I wanted to see all the objects in scanlist #8, I would like to be able to do that. What I found is, by sorting by scanlist, objects that are in scanlist #'s 1, 4 & 8 appear at different locations in the view screen, which is seperate from the bulk of objects in the view of objects that are contained ONLY in scanlist #8 (if I scroll directly to it), at least when using the "CONV Objects" tab.
I did discover that you can view all the objects in a particular scanlist under the "ALL Objects" tab, but you can't edit scanlists there. Perhaps you could add something to the "Sort Objects" function under the "Edit" drop down menu, to select just one scanlist?
Just my user preference...thanks for all your hard work...Your Software ROCKS!!! and so does this scanner.
Paul
P.S. I upgraded to V 1.55 today.
