Official Starrsoft WIN500 Software Thread
scan-pa
RRDB Admin
Lebanon, Pa.
Official Starrsoft WIN500 Software Thread.
This thread is to report & Discuss anything related to The WIN500 software.
Starrsoft WIN500 Software: http://starrsoft.com/ Version 1.07 is now Available **** updated on 11/27/2007
System Requirements
In order to run Win500, you'll need the following:
* A copy of the Win500 program
* A PSR-500 Scanner
* The blue GRE USB Scanner Programming cable that came with your PSR-500.
* A Windows (2000, XP, Vista) PC. Sorry - 95, 98, and Me are not supported.
NC3Z
Pamlico County, NC
Web Import error
On my work Desktop/network I get the Win500 error below whenever I hit the Start button.
"The HTTP (web) request returned error 403. Please ensure that your Internet connection is ready."
It works on a PC off that network. Is there a specific port that is used?
DonS
Franktown, CO
Win500 uses the Internet Explorer settings to access the RR database server. Is IE set up correctly (can you use IE to "browse")? One thing to look at might be any proxy settings required by your environment.
NC3Z
Pamlico County, NC
Yes I can use IE to browse. There is a firewall and there are proxy settings.
smason
Alberta Canada, Eh!
While waiting for my new PSR-600 to arrive, I'm playing with Win500. Looks very impressive so far.
Love the remote control, had a peek at Don's 600 via the client, very cool!
Quick question, any chance of there being client software for Windows Mobile?
I'd love to use this on my Windows Mobile device.
Also, can somone point me to the format info for a .csv file to import?
Thanks,
Steve
DonS
Franktown, CO
I'm playing around with a WM client now. It's nowhere near complete, though. It will likely appear on the Win500 web page eventually.
Win500 does not currently import CSV files.
bubbaearle
Vista problem starting Win500
I am getting an error message that Wn500 (Win97 too) has stopped working. When I start the program(s) I get the Loading..... box and them jumps straight to the error box.
I have not made any changes to my system in a while.......Windows Vista Home Premium
Any suggestions as to what to check first? :confused:
Here's what the Problem Reports and Solutions thingy reported......
Product
Win500 Scanner Utility
Problem
Stopped working
Date
8/22/2008 6:51 PM
Not Reported
Problem signature
Problem Event Name: APPCRASH
Application Name: Win500.exe
Application Version: 0.1.5.7
Application Timestamp: 48a1e564
Fault Module Name: StackHash_4eab
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Code: c0000096
Exception Offset: 013a340e
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 1033
Additional Information 1: 4eab
Additional Information 2: 7972284d3632e6a45f3480d9583348dc
Additional Information 3: a63d
Additional Information 4: 24db237350bc91b531e253ab05da070f
Files that help describe the problem
Version.txt
AppCompat.txt
memory.hdmp
minidump.mdmp
Product
Win97 Scanner Utility
Problem
Stopped working
Date
8/22/2008 6:52 PM
Not Reported
Problem signature
Application Name: Win97.exe
Application Version: 0.1.1.6
Application Timestamp: 4823233c
Fault Module Name: StackHash_0a12
Exception Offset: 003a340e
Locale ID: 1033
Additional Information 1: 0a12
Additional Information 2: 7ada01ff8489d36647e9f5aaf57561ee
Additional Information 3: 5acd
Additional Information 4: f06863ac57ce8ee38a7a457b1f19c03c
Version.txt
AppCompat.txt
memory.hdmp
minidump.mdmp
wp3539
Sound Recording Feature Request/Question
Does the audio recording feature use the audio input to trigger recording or the active channel/talkgroup feed from the data path?
Is there a way to add a feature to generate a mono wav stream from one side of the stereo input? I have a scanner and a mobile transceiver hooked to the same audio input. I use Scanner Recorder Pro to record the analog transceiver data from one side of the stereo input and I plan on using the other side of the stereo input to record with win500. Scanner Recorder Pro has this feature where you can record only one of the stereo channels into a mono output so you can use a single soundcard input to record two scanners/radios at the same time. Could you please add a feature that would generate the mono stream from one of the stereo channels in win500?
Thanks!
bacon
Tippecanoe County IN
Separate LCD Window Title Bar Bug
Hji Don,
I think I found a bug in the Separate LCD Window.
Version 1.57 Revision: # 3 is not working properly for digital (DG) talkgroups on the Motorola Type II SmartZone Omnilink TRS (Analog and APCO-25 Common Air Interface) I monitor (Indiana SAFE-T). The applicable coded squelch or "radio ID" information does not show in the "Separate LCD Window” title bar during the transmission. What happens is the information will pop up only for a very quick and almost imperceptible instant at the end of the hold time on the digital talkgroup.
It does work as advertized for analog talkgroups (VC) and conventional channels; during an analog transmission, the title bar shows the coded squelch and radio ID (or channel number if set to show instead of "TSYS" when radio ID isn’t decoded).
DonS
Franktown, CO
Recording is triggered by data from the PC/IF port that indicates a transmission is starting/ending.
Not at present. The audio functions I'm using don't allow me to split the input into L/R channels. I'll investigate it though, to see how much work it would be to change things.
K7MQ
Flagstaff, Arizona
V 01.61 Win500
Under the SRCH/SWPR Objects tab ... I have entered about 20 short searches. The original info that was there when you have no entries (Group/Channels .. selection not available for the object etc.) covers the entered search frequencies. Am I missing something. Is it only suppose to have a lesser number of search ranges?
Lou K7MQ
DonS
Franktown, CO
The options in the "Groups / Channels" box below the "grid" change depending on the type of search / sweeper object selected in the grid itself.
lorin
San Jose, California
Help with Tsys Object " Type"
In the Win500 file there is a tab called " Tsys Object" in that folder there is another tab that is " Type" in that field It asks for the different types? Iam not sure what type to select for the desired frequency. I have an option to choose, EDACS STD, EDACS Narrow, LTR, P25 AUTO, P25 Narrow. How do I find out which of options to put into the Type box? Is there a way to know what this box needing? Most of my frequencies that I am programming in are in the 867.3375 or 488.7250 or 866.2250 range-trunking. Can some one please explain how I find out the "type" so I know what to put into that box.
Lorin Engler( New to the scanner world )
