Admin0140434
All right, now enjoy your new scanner!
edmscan said:But did she have it programmed already when you got there ?![]()
crashcrew said:,,,and why couldn't this "nice lady" bring the package to you, or tell the UPS guy "this isn't me, you want so and so.."
Hello,Admin0140434 said:couldnt find this in the maunual... but maybe i missed it...
when scanning a TRS... if i dont program Icall ID's or Status bit ID's in the radio... do i have to be in ID search to hear these transmissions or can i be in ID scan and still hear them?
cliffcor said:Wonder why the Scanner Master folks are getting units out slower then others. Just kinda disappointed that it won't arrive by the weekend I guess.
h8tdigitalradio said:Hello,Admin0140434 said:couldnt find this in the maunual... but maybe i missed it...
If you want to scan for Private Calls, you will need to be in ID Search Mode. If you want to scan for I-Calls or Private Calls while in ID Scan Mode, program a TG as i00000 for EDACS or 700000 for Motorola in a Group List.
HTH
73
Dave AKA The Tripzter :shock:
Voyager said:Uhhh... isn't there one too many 0s in that Motorola ID, Dave? (70000)
Joe M.
n5gqb said:I just programmed in one of the local 800 ltr systems in the 246t and I'm observing something that "might" be a problem. The radio at ramdon seems to "drop" a conversation and start scanning as if it stopped decoding the subaudible data stream. Also related is sometimes it takes several seconds of scanning thru the system before it locks onto an id already in progress. Signal strength is not a problem, no fading in or out, squelch is set accordingly and the LCN is correct and I am only scanning the one system.
I am comparing it to my 296d right now. The 296d will stop on a conversation and sometimes the 246t will be silent until several seconds later, sometimes it won't stop at all and sometimes they will stop at near the same time.
The 296 will hold the conversation and while on occasion the 246 will drop it and start scanning.
I too noticed this only when "Close Call" . is enabled. Not a big deal to me anyway. Also watch out for the delay settings, set them to a miniumum this too made a difference.
Anyway if any of you are into ltr scanning could you check things out on your end (with another ltr scanner beside) and see if you can duplicate the same thing I'm noticing?
I am not saying there is a problem with the 246, it maybe something at the ltr repeater site. However I would figure the 296 would act similairly.
I am under slight assumption that the subaudibable signalling gain (for lack of better words) is set to low (if even adjustable) on the 246 and also that the local ltr repeater sight has there gain turned downed low too. Possible the 296 gain threshold is set more sensitive thus holds the conversation. I know I'm getting sort of technical on the matter but for those of you that are hams or work with two way radios know what I'm talking about (you can turn down the pl (subaudible) gain pot on you radio so low that it'll no longer opens the squelch).
More listening is in order......
Sly n5gqb
UPMan said:When you HOLD, scrolling will step through all programmed channels. However, the GRP icons at the bottom of the screen do indicate the channel group assignment for the current channel, and scrolling steps through in channel group order.
baddandy23 said:anybody else order form universal-radio .com? still waiting for mine...
Landman said:There is a sticker inside the battery compartment that says to use only alkaline or NiMH batteries. Will it damage the scanner if I use Energizer E2 lithium batteries as a backup when I am on the road and the NiMH batteries go dead? I understand that the lithium batteries put out a slightly higher voltage than alkalines, say 1.7 to 1.8 volts or so.
