Official Uniden BC898T Scanner Thread
blantonl
Founder and CEO
Staff member
Super Moderator
San Antonio, Whitefish, New Orleans
This scanner has received FCC approval, and appears to be similiar to the BC895 with Motorola, EDACS, LTR, CTCSS/DCS capabilities.
Looks to be a really nice scanner for most areas where digital operation is not used.
Voyager
RedAlert
Dayton, Ohio
I had hoped that Uniden would not abandon the larger bc-895 tabletop design.
I would be happy if it will track both conventional and trunked at the same time. I think thats what trunktracker III does.
I would be really happy if it includeds service search bands this time. The bc-895 caimed to have service search bands, but that turned out to be a misprint in the original manual.
I was searching for more info on this new bc-898t as I can not read pdf files that start with https on my webtv.
One site claimed that it's frequency range started at 29.0 mhz while the Grove site stated 25.0 mhz?
Here is the info I got from the Grove Website, but I'd like to see a picture if anyone can convert a pdf image to html and post it...
Uniden has a new scanner the BC-898T. It has just been FCC type accepted (AMWUB322).
BC-898T Feature HighlightsTrunk Tracking ­ Follow 800 MHz trunked public safety and public service systems just as if conventional two-way communications were used.
500 Channels ­ Program one frequency into each channel. You must have at least one channel programmed to use the scan mode.
10 Banks ­ Each bank contains 50 channels, large enough for even the largest trunked systems or useful for storing similar frequencies to maintain faster scanning cycles.
Signal Strength Meter ­ Your scanner's signal strength meter displays the relative strength of an active transmission, using up to five separate indicators.
CTCSS and DCS Squelch Modes ­ prevent interference from stations not using the mode you select. The scanner's search mode shows you if the station you are scanning is using CTCSS or DCS tones.  CTCSS (Continuous Tone Coded Squelch System) ­ When CTCSS is activated, your scanner tunes to a frequency only if the associated CTCSS tone youprogrammed is included with the transmission. You can also use this feature to search for a CTCSS tone when monitoring a transmission.
Subaudible Tone Search ­ Lets the scanner search for and identify agencies transmitting CTCSS or DCS tones. You can identify up to 50 CTCSS tones. This helps you find stations using these tones.
17 Bands ­ Includes 17 bands, with Aircraft and 800 MHz.
25 MHz-956 MHz ­ Your scanner covers an extensive frequency range so you can monitor most of the transmissions in your area. Note: The scanner's frequency coverage is not continuous and does not include the cellular telephone band.
10 Priority Channels ­ You can assign one priority channel in each bank. Assigning a priority channel lets you keep track of activity on your most important channel(s) while monitoring other channels for transmissions.
VFO (Variable Frequency Oscillator) Control ­ Turn the large rotary tuner to select a desired frequency or channel.
AutoStore ­ Automatically stores all active frequencies within the specified bank(s).
Weather Alert ­ Lets your scanner alert you when a SAME weather alert is transmitted on a NOAA weather channel. The scanner also displays the transmitted SAME code. This helps you quickly find out about severe weather in your area and lets you  avoid false alarms.
The BC898T is designed to track the following types of trunking systems.Motorola Type I, Type II, Type IIi, Hybrid, SMARTNET™, and PRIVACYPLUS™analog trunking systems*, which are extensively used in 800 MHzcommunication systems.LTR trunking systems; EDACS trunking systems (including EDACS SCAT - Single Channel AutonomousTrunking)Note: This is an analog only trunk tracker. It will not do APCO-25digital comms and can not be upgraded to do digital communications.
Channels: 500Banks: 10 (50 channels each)
Service Bands: 17 ­ preprogrammed search bands (including the NOAAWeather Service band)Frequency Range:25.0-27.995 MHz Citizens Band/Business Band28.0­29.995 MHz 10 Meter Amateur Band30­49.995 MHz VHF Low Band50.0­54.0 MHz 6 Meter Amateur Band137­143.995 MHz Military Land Mobile144­147.995 MHz 2 Meter Amateur Band148­174 MHz VHF High BandAbove bands in 5 kHz steps108­136.9875 MHz Aircraft Band216-224.9875 MHz VHF High Band225­399.9875 MHz UHF Air Band400­419.9875 MHz Federal Land Mobile420­449.9875 MHz 70 cm Amateur Band450­469.9875 MHz UHF Standard Band470­512 MHz UHF "T" Band806­823.9875 MHz "800" Band850-868.9875 MHz "800" Band895-956 MHz "800" BandAbove bands in 12.5 kHz steps
NOTE FROM REDALERT
( Does the above seem like the same misprint on the BC-895?)
some service search bands should jump across several bands to cover a particular service, ham, police, ect. right?
END OF NOTE
Operating Temperature: ­20°C to +60°C
Scan Rate: 100 channels per second (conventional mode)
Search Rate: 300 steps per second
Scan Delay: 2 seconds
Audio Output: 1.8W nominal into 8W internal speaker
Power Requirements: 12 VDC 500mAh (internal battery or AD140U ACadapter)
Antenna: 50 ohms (Impedance)
External Jacks: Antenna Jack BNC TypeExt. Speaker Jack 3.5mmLine Out Jack 3.5mmAUX Jack RCA TypeDC Power Jack 5.5mmRemote Jack 5 Pins
Size: 101/2 in. (W) x 73/8 in. (D) x 31/2 in. (H)
Weight: 3.8 lbs
Features, Specifications, and
Availability of optional accessories areall subject to change without notice.
Voyager
Really? Where is their DIGITAL base station? (no, the BC796D is a mobile, and doesn't have the same functionality of the BC895XLT)
Joe M.
INDY72
Indianapolis, IN
BC896-D is a combination Mobile/Base type of scanner. In my opinion any of the 12 volt operating scanners could be defined as Mobile/Base as they can operate iether way. So now the lines get fuzzy lol, although as far as I know the only way you know for sure that a Bearcat is designed for mobile exclusively is by the lovely old added extension of -A to its listing, such as BC350-A.
Voyager
True enough, but that's why I said that the 796D (I'm assuming yours was a typo) doesn't have the same functionality of the BC895XLT. (I.E. the large buttons, the tuning knob, Etc)
For that matter, with a power supply, you could call any portable a base, too.
Joe M.
Voyager
Re: the new uniden scanner s
kmartin said:
i wish uniden, RS, GRE, or someone would make a scanner with EDACS provoice digital .. if anyone has news about one in the works email kyle at delobar@earthlink.net
The problem with that is that PV is proprietary, so nobody can make one without permission to use the format. No permission, no PV scanner.
Joe M.
ka2mek
I too am wondering what UNIDEN will ask for in regards to the price of this radio.
Rob - KA2MEK
Dubbin
Findlay Ohio
I am wondering if this rig will carry over the data port that the 895 has and did uniden incorporate the ability to do trunking and conventional scanning at the same time
Im willing to bet that it will have the data port and scan both at the same time.
edit: After looking through the manual it will have both of those features.
AZScanner
Somewhere in this room. Right now, you're very col
ka2mek said:
I am wondering if this rig will carry over the data port that the 895 has and did uniden incorporate the ability to do trunking and conventional scanning at the same time or (if it carried over the data port)will we still need WINSCAN software to enable it to trunk and scan conventional freqs at the same time?it does say "TRUNKTRACKER III TECHNOLOGY"hrm?
Rob - KA2MEK
From what I gather, it should be more like the 245XLT in that it will track multiple systems without software. If I'm incorrect, I'm sure someone in the know will post a correction.
I tried looking in an online owner's manual but the one I found was incomplete.
-AZ
EricCottrell
Boston, Ma
Hello,
I have been listening to Passport LTR systems down in the 216 to 222 MHz band. Systems are using 6.25 or 12.5 KHz steps. I was looking at the new BC-898T manual and noticed that it has 12.5 KHz steps on the 216 MHz band. It also has the 6.25 KHz step so I got one. I am trying it out tonight and so far it is working good. I like the separate keys for mode and step.
But one surprise was the rapid CTCSS/DCS search that is likely to be in the future Uniden trunked radios as well. It searches both CTCSS and DCS at the same time! Unlike the Pro96 the code display goes away with the transmission. You can do CTCSS/DCS searches when doing frequency searches.
73 Eric
EricCottrell
Boston, Ma
First Impressions
I have not really used it alot but I like the 898T.
So far sensitivity and image rejection are similar to my 780. I got a few strong transmitters in the neighborhood and get a few 470 MHz transmitters in the 406 MHz band.
Panel layout is similar to the 895. It is bigger than the 780 and I suspect there is some more air inside. I found having the mode and step easily accessible is useful. On the 780 it is under a menu. This was not a problem until I started searching down in the 220 bands for systems. The 780 has the wrong step size and will not do 6.25 KHz steps. The 898T has a 12.5 KHz stepsize on 220 which is an improvement and will do 6.25 KHz steps. It appears the 6.25 KHz step size is used in the 220 to 221 MHz band for FM systems.
The 898T is considered a base unit by some. It comes with a 12V 500 mA AC adapter and has the typical coaxial power plug. The manual mentions an optional mounting bracket and there are holes on the side for the mounting bracket. The 898T manual is bigger than the one for the 250D. It is letter size format.
Trunker works by using the BC895 setting. I have not opened the unit up to see about tapping. Like other Trunktracker III scanners you can send serial commands and use the keypad at the same time. I am glad that Uniden has released the serial protocol for their scanners. You find those handy command options like the step override option available with the RF command.
The really nice feature is the CTCSS/DCS searching. The 898T displays the code in about a second and searches for both CTCSS and DCS. I noticed it will decode tones with a weak signal of about 50 percent quieting. As with other uniden scanners it can send the tone code it detected over the serial port, so coupled with the rapid decode, a CTCSS/DCS logger application is possible.
This scanner does not have digital voice decoding or alpha tags. I really like alpha tags and already have a couple of scanners with alpha tags. I got this unit to do some trunker and frequency search stuff.
A couple of months ago I wanted a "cheap" serial control scanner that I can use with trunker so I decided on the BCT8. It will fill the basic need but it has some limitations such as fixed step sizes, and no Motorola 900 Trunk selection. So it will work for most trunked systems. If I was making the decision today I would pay the extra money and get the 898T instead. If they had a non-alpha Base/Mobile (i.e. smaller) unit with 898T features (minus a few buttons) then it would be even better.
73 Eric
doctordave
Does the 898 support the splinter VHF-Hi freqs with its step selection? I would assume so, but want to confirm before shipping one in.
Thanks.
Dave
