PSR-800: Officially upgraded to 1080 with fw v4.8 misses alot of DMR
Paco-Jerte
You Member, Member!
34.0500° N, 118.2500° W
had it done by whistler with latest v4.8 but seems to miss alot of "live" DMR via search mode.
Anyone have the official 1080 v4.5 to load to mine? checked whistlers site but all they have is the latest v4.8
I did msg Wendy just in case that's the only way done legally. Thanks :D
EricCottrell
Boston, Ma
Hello,
The legacy upgrade uses a different firmware file than an actual 1080, so there is likely no downgrade path.
73 Eric
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
My two upgraded PSR-800s work great with DMR for conventional. Set the slot, CC, and TG to any.
Is the traffic you are missing trunked or conventional?
Sent from my SM-G930V using Tapatalk
Paco-Jerte
You Member, Member!
This happens only with "Limit Search" as it finds DMR frequencies it just keep going even thought the search delay is set to 2 seconds.
Don't have those issues with a Pro-18 with fw v4.5,
Paco-Jerte
You Member, Member!
For some reason when Whistler did my Legacy upgrade they loaded
DSP 3.0
FW 4.8
updated to DSP 3.1 and now DMR stop fine during Limit search.
Wonder why Whistler didn't load 3.1 to begin with :confused:
Scanner seems to be working good for now. :D
