spraguer10_8
I have a PRO-94 and am trying to set up a trunked bank to monitor the TRS on Offutt AFB but I'm not getting anything in trunked mode. I CAN hear conversations when I take the scanner out of trunk mode and lock out what I assume is the data channel.
I'll throw out everything I've done so maybe someone can tell me where I went wrong or what else to do.
1) The RR database identifies it as a Motorola Type II system. Since the frequencies are in the 406-410 range I set it up on the Pro-94 as "E2-UHF' (Motorola Type II, UHF frequencies).
2) Entered following frequencies:
406.350 406.750 407.150 407.550 407.950 408.750 409.550
(These are from from the RR database)
3) Hit SRC to start searching for the data channel.
4) Scanner stops on what I assume is the data channel
5) Nothing. Again, if I turn off trunking and lock out the data channel, I get transmissions.
I've read the manual several times and still can't figure out where the problem is. Greatly appreciate any suggestions.
-Thanks
-Thanks
