Oh my..one more thing
Mom25
Arizona
I think I got the feed up but the screen keeps flashing back and forth from communicating with scanner and not? I don't think it's picking everything up. I did have to change the COM port on the program to 4 as that is what my cord is in. Could that be the problem?
Astrak
Mesa, AZ
The line in on the computer should be plugged into the headphone jack of the scanner. The comport of the scanner is only for programming or remote control of the scanner.
Okay, after monitoring your feed for a little while it sounds like you need to move the antenna around a bit until you find the "sweet spot" for P25 reception. You'll have to play with it a bit until you can find a spot for the antenna that receives perfectly.
Mom25
Arizona
Perfect thanks! Yes i have been working on the reception. Work in progress i guess:)! Thank you for everything!
