Ohio MARCS (Mt. Orab) brown county Tower
jymypy123
Mt.orab ,Ohio
The Mount Orab ohio Marcs tower is up and running the frequencies for that tower are:
868.4375 control channel
866.8625
868.1375 night be alternate control channel
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Hi,
I need some more information from you / your scanner.
I need to now the System ID, Site ID and Alias. Your scanner should at least display the first two, and it probably will display the Alias depending upon how you have your settings in your scanner configured.
Can you get the System ID and Site ID from me? The Site ID will be a number from 1 to 64. The System ID will be [probably] be 6F16.
The alias would be a 6-character [usually] alphabetic abbreviation of the site location.
IF you could get at least the System ID and SIte ID for me I'd appreciate it.
Mike
mtindor
FMP24 PRO USER
Can this information be found by analyzing the control channel on the pro 197?
Yes indeed. It should show up right on your display.
Bottom line might look something like:
99% SID:6F10 S59 (yours will be diff)
(signal strength / System ID / Site ID)
and it may alternate with:
CT: 97.30 SAMHIL (yours will be diff)
(Connect Tone / Site Alias)
It would be useful to know what everything on both of those alternating bottom lines says.
m
jymypy123
Mt.orab ,Ohio
System ID: 6F16
Site ID : S63
Tower Name: M- Orab
That what was showing up on battom of screen
jymypy123
Mt.orab ,Ohio
your welcome if you have any more question you can find more information on the license that are know posted on the fcc. There is a link to the license on the other mount orab post I summited.
