Ohio MARCS programming
spacenerd
Wapakoneta,Ohio
I have just received my Uniden BCD996T and I am still learning how to program. I have a question about programming Ohio MARCS. I set the system using Motorola 800MHZ Type II Standard. I am hearing lots of traffic but sometimes part of the commincation is distorted. Is this normal or have I set this up wrong. Should I have used APCO 25?
Thanks,
Spacenerd
rdale
Lansing, MI
You have it set correctly. You may need to tweak your error correction setting, or you may just be getting a bad signal.
spacenerd
Wapakoneta,Ohio
Thanks for the info. Can you you tell me how to tweak the error correction setting on the BCD996T I cannot find anything in the manual.
Spacenerd
HIP
Toledo,Ohio
Error Correction?
Page 3 of the 996 post release thread has the instructions for this.can not remember exactly which post it is.
dr400
I had to set it lower than the default, seven worked for me but your conditions may vary. I need to monitor three towers to get coverage of all I want and two of the three are relatively low signal strength at my location.
