Ohio State Police General
vanderneut
What freqs can I load for monitoring OSP across the state with reasonable success
mmartinfan
Banned
In a house in Ohio
You can still put in the 42.xxxxxxxx freq but that is less and less comman now.
Otherwise you would have to enter whatever sites are close to you and hope someone is listening all over the state.
FPO703
Planet Earth
They also operate on some 154.**** and 155.**** frequencies in various agencies.
More and more posts are migrating over to MARCS, though.
Nasby
Ohio
On sunny days OSP often use aircraft to catch speeders. When they coordinate with other agencies, they use Innercity 155.370.
qoatzecotl
Kendallville, IN
155.370 is INTERcity, not INNERcity
radioscan
Radio Sensei
Southern Ohio
In the southwestern part of the state they use the four TAC channels for
aircraft speed enforcement, mainly TAC 1 42.560 with a PL of 156.7.
This is especially true for I-75 from Sidney south to I-275.
xusmarine1979
Louisville, Ohio
What about the NE and Central Ohio Aviation. Anybody know what freqs they use for OSP aviation in these areas?
xusmarine1979
Louisville, Ohio
I believe I am hearing OSP Aviation on Intercity (155.3700). Is there another frequency in the Stark area that they may patch that to? They are nailin' a lot of people but I can't tell where they are. I know the last time I drove through Tuscawaras Co. I saw their bird in the air with two troopers that had different people pulled over.
So besides Intercity, anybody happen to know?
FPO703
Planet Earth
The OSP Planes will check in with the patrol posts where they will be working near. Recently OSP planes have been working with Tallmadge & Stow PDs in various places. Post 76 units have also been in on the fun. The planes use 155.370 for comms with Tallmadge & Stow PDs and MARCS for the OSP units.
xusmarine1979
Louisville, Ohio
I can't really tell where they are, I can hear the bird but not the cars. I'm just hearing them on the base scanner. I hear them while at home too.
LawnCowboy
Cincinnati (Hamilton Co. West)
OSP MARCS monitoring in SW OH area
caution, extra brain skills required to understand this.. hehe
ok.... needing a little feedback.... starting to monitor OSP MARCS for the SW Ohio area (around Cincinnati).... I load in the control channels on my PRO-96 for A FEW of the surrounding areas (Cherry Grove, Northbend, Loveland, Cincinnati, Greenhills) from the database in ONE bank (putting an FM channel in between the control channels so the bank doesn't lock onto only ONE control channel as I believe I've read) as well as the TalkGroups for Post 9, 13, 83 and maybe one or two others.... now as I hear a conversation and see the control channel being used by the description I've loaded from the location (ex. Loveland)... I notice that the control channel seems to change as the talkgroup stays the same???? I seem to be hearing full conversations and am guessing just the way I have them labeled is throwing up question marks for me... maybe I just need to take the control channels as I have for the FEW surrounding areas and label them generally (I.E. OSP... instead of the location name) but I don't understand why they are changing control channels?? perhaps I'm not hearing the same conversation over different control channels but perhaps I'm seeing the same OSP Post using a couple different control channels???? I guess I'm missing something here?
qoatzecotl
Kendallville, IN
Re: OSP MARCS monitoring in SW OH area
I wouldn't worry about it, if it's working OK. It's not a problem at all. You probably actually ARE hearing the same TG on more than one site...
LawnCowboy
ok, so I seem to be getting the same traffic on 2 control channels it looks like at the moment (cherry grove and loveland).... so why wouldn't it be getting simulcast on the rest of the area stations? now I just heard another conversation on only ONE control channel... perhaps its just the scanner not picking up the other control ch. at the moment.... all 4 or 5 come in with strong signals though.. ... still trying to figure this out. :roll:
FPO703
Planet Earth
If you have the OSP Post affiliated with the post closest to the post itself, you'll hear the traffic on that tower. If a mobile or handheld is affiliated with a tower at another location, you will hear that traffic on that additional tower, as well.
Every tower that has a radio affiliated with any talkgroup will carry the radio traffic on it.
Example:
Cincinnati OSP Post is closest to the site in Cincinnati, the traffic will be on that site. A mobile is near the Butler county line and unable to affiliate with the Cincinnati site, but, is able to affiliate with a site in Butler County, then, you'll hear that traffic on that site.
LawnCowboy
think I have it figured enough to understand what's going on... thanks for the explanation.... just went ahead and loaded description as OSP for all the sites and then I don't get confused when talkgroups come up under different locations.
still have some detailed questions but as ya said, if it's working, not worrying about it.
radioscan
Radio Sensei
Southern Ohio
You may find a better way is to label the MARCS sites as it is in the rr.com database.
Mine is setup as follows.
MARCSLebnon
iCall
MARCSDayton
iTAC-1
MARCSDunlap (Greenhills)
iTAC-2
MARCSCincy
iTAC-3
MARCSChrGrv
iTAC-4
MARCSLveland
etc........................
