OK guys...open to suggestion here....
I have a RS Pro 2052, as many of you know, the date code is 03A03. Now I think there was an upgrade made to this unit that starts with the date code 04A03, but I don't know if it applies to my issues.
The first is with the Mont Co Fire Simulcast on 154.1600. I am continually receivng bleed over from this channel on just about any frequency I have entered in the 139.xxxx - 171.xxxx range. The closest tower to me is about 4-5 miles. I added an FM trap, at the radio end, in hopes of reducing the bleed through, but it has not helped. The simulcast on 153.9500 does not bleed through.
The second is with MSP freq's. I live mid way between Rockville and Frederick. I sit up on a ridge approx 100 - 200 ft above the rest of Montgomery Co. I hear the troopers and dispatch from Frederick just fine (39.4000) but I can only hear the dispatcher (39.3200) from Rockville. There is a mountain (Sugarloaf) that is between my house and frederick (I live not too far from the base). Interestingly enough, to add to the mix, is I can clearly hear the Carroll County Barracks and cars all the way out in Westminster.
I can also hear the low bands out in Jefferson County West Virginia.
You input and infinite wisdom would be appreciated.
Paul
Paul
