CanesFan95
The more I try to read up on grounding for lightning safety, the more I come across opposing debates and can't figure out what is right or wrong. It seems like no matter what someone does to ground an antenna, there's always someone on a forum who'll tell you you're doing it wrong. Doesn't even matter what you do. Randomly set up something or do it by the book and someone somewhere will always say you're wrong.
Like this thread for example, where there's a guy on there who insists that you shouldn't add more ground rods to a house. But then there's other times I'll see a thread where someone says to add another ground rod and "bond" it to the original ground rod (I believe "bond" simply means connect 'em with a piece of wire?).
If the goal is to ground the antenna and mast in as straight a path as possible directly down, then the problem is you might not be able to place the antenna right next to the original ground rod. So final answer, is it OK to add another ground rod or not??
