Oklahoma City EDACS
bwilborn
Evans, CO
Greetings,
I will be passing through OKC on my way to Texas this weekend and could use some advice on this system. I'll be programming a 396 and a 330, and was wondering how much of this system is supported by either scanner.
I notice that the system is listed as "ProVoice and Analog", and that most of the talkgroups I'm interested in are Digital. Does this mean that those are using ProVoice? I'm from CO, so I've got our statewide digital P25 system configured already, and Denver's EDACS standard system. How different is the OKC system from the Denver system?
Also, I noticed that some of the talkgroups are simulcast on other frequencies in the VHF and UHF range. Would it be better to just program those in?
Thanks in advance!
-- B
dstew67
Missouri
Greetings,
Thanks in advance!
-- B
You're on the right track. Those indicated as digital are indeed using ProVoice. Also, you can program the old VHF PD dispatch freqs to listen in on PD. You're out of luck with fire. Both scanners should do fine picking up the system itself.
bwilborn
Evans, CO
OK, so I'm basically boned for the EDACS system then, right? I guess I'll just use the old frequencies. Thanks!
-- B
eharlow
Owasso, OK
Pretty much...You should pick up all PD traffic on the old freqs though. You're just boned on the fire stuff. All public works stuff is still analog though.
