OKWIN P 25 bandplan
goofy7777
Does anyone have the correct bandplan tables for the OKWIN P 25 system. Need for Pro 96 or 2096. Older Motorola system works great but newer P 25 phase 1 system is not working.
nd5y
Wichita Falls, TX
This is what Unitrunker shows.
I don't know what format ARC96 uses or how you would enter it.
Base Low High Spacing Slots
851.00625 00-0000 00-4095 6.25 1
851.01250 02-0000 02-4095 12.5 1
tvengr
Well Known Member
Baltimore County, MD
Set the Mot 3600 and 9600 Systems Bandplan to Normal. The P25 system should load the bandplan. If that doesn't work, select Multi Tables on the Mot 9600 System Bandplan and it should load. P25 is 9600. If you have a problem with the P25 system on the Pro-96, adjusting VR4 can make a big difference. VR4 is marked on the circuit board. Adjust for best P25 decode. Please let me know which one works. It has been a while since I programmed a Pro-96. I have ARC96. If you have problems, attach you programming file.
goofy7777
VR4 was the key! Actually in the pro 2096 it only has VR1-3. Adjusted VR3 nearly a quarter turn and BAM! Thanks much!
tvengr
Well Known Member
Glad to hear you got it working. Did it work with the Mot 9600 Systems Bandplan set to Normal or did you have to set it to Multi Tables?
