To anyone looking to acquire commercial radio programming software:
I found an old base station, a GM 23B, and was wondering if it was still viable, and legal. I'd heard 23 channel units aren't anymore. And yes, I'm studying for my Tech license, so this isn't going to be my only radio use.
Your "old" GM 23B should still be legal since no license is required for CB use and as long as it is/was FCC certified. It is probably still viable too and while 40 channels units are being sold now, if the old still works why not use it for just a little fun and nostalgia.
And good luck on your Tech license so you'll need another radio for that use anyway...
It's certified, running all 4 watts. Got to find an antenna. Not much cb traffic around here, maybe I can stir some up, especially being 6 miles from a major freeway.
If you have a working older unit, good for you. I have a working 23 channel mobile unit. I have used it in conjunction with 40 channel units. (The only problems are 1. The obvious frequency limitations, and 2. I have more transceivers than I do antennas.) Anyways, they're still usable, so why not hold on to them ?
It is more of a new project now. It receives quite well, but doesn't seem to transmit. The meter will move when TX, but after releasing the mic button, it squeals for a few seconds, and then goes back to normal. Best antenna I could come up with is a car mag mount, and while I've got a large cast iron firepit in the backyard, it's on a deck, and not exactly a good ground. I did take it apart, and it is a Uniden in disguise.
Any repair ideas?
