The frequencies/talkgroups are supposed to be deleted eventually. Sometimes they remain for a long time because either A) they're forgotten about or B) an agency that has moved to a new system (800 trunked from VHF, for example) may still have the physical equipment installed "just in case".Deprecated – This tag denotes a frequency or talkgroup that is no longer used. This tag should be used only temporarily during transition/migration periods for new radio systems. Frequencies and talkgroups should be deleted when they are truly obsolete.
Unfortunately, in many cases, the organization has moved to a new system, sometimes with the agreement that they would cancel their licenses and make their old frequencies available to others in the region, but has reneged on the agreement and continues to keep their old frequencies. In some cases, the base stations and antennas were unbolted, but since they're carried on licenses, they remain obstacles to new systems who might have to ask them for "concurrence" in order to operate. Sometimes that permission is denied, even though the system is not used. This effectively "warehouses" that frequency within the region.The frequencies/talkgroups are supposed to be deleted eventually. Sometimes they remain for a long time because either A) they're forgotten about or B) an agency that has moved to a new system (800 trunked from VHF, for example) may still have the physical equipment installed "just in case".
That is what is supposed to happen already but the FCC has no way to enforce it.the FCC should require that a license holder actually USE the frequencies they hold license for. If they aren't used then they should be placed back in the pool and re-issued to other users.
All of that is true. RR's strength is that it has information about what is actually used and how it's used based on observation. You have the ability to judge the frequency's worth and whether or not you want to monitor it (and to provide feedback). That's something ULS can't do. The FCC does require systems to be "built out." The spectrum audit of 2001 pruned a few licenses nationwide, but the only thing that was necessary was to respond. No one is budgeted to do a site-by-site audit of physical plant. It's impractical considering the expenses for travel, lodging, and manpower required. So, looks like we're stuck with the honor system and random inspections. In the meantime, prospective licensees are stuck protecting that piece of paper that may have been active at one time, held for "the big one" (that once-in-a-career call that always seems to happen when you're out of town), or is completely fictitious.As long as an agency holds a valid license for that frequency, it should be listed in the data base. The admin here doesn't have any way to check on usage. Other than what we tell RR. That said, the FCC should require that a license holder actually USE the frequencies they hold license for. If they aren't used then they should be placed back in the pool and re-issued to other users.
It will be in the searchable FCC database here, but only frequencies that are confirmed in use (or "usable" if confirmed) will be listed in the main RR database. Generally speaking unused frequencies will be deleted. The "Deprecated" function tag is intended primarily for a temporary marking of old frequencies when an agency has migrated. If you find stale "Deprecated" tags on something that is confirmed dead then please submit an update to the database.As long as an agency holds a valid license for that frequency, it should be listed in the data base. The admin here doesn't have any way to check on usage. Other than what we tell RR.
Why does the database keep old frequencies in the database and make them as "Deprecated". I understand it's for "reference" purposed but it's confusing also at the same time. Thanks.
deprecate: Definition, Synonyms from Answers.comComputer Science. To mark (a component of a software standard) as obsolete to warn against its use in the future so that it may be phased out.
