Old MDC 1200 Signaling
gtaman
TACSAT
GALAXY 19 91.0° W
Does anybody have or can make a sound bit of the old MOTOROLA MDC 1200 Signaling noise. It was heard a lot on the FDNY radio during 9/11 I believe the old SABER SERIES can still make this older version of this signaling. Also if any one has a video I would greatly appreciate it.
Thanks Matt
SimpleSkye
Northern California
FDNY back then used to use a proprietary Motorola format called "ATIS". It sounds similar to MDC, but completely incompatable with it. It is only availiable in HT1000 & Visar radios.
gtaman
TACSAT
GALAXY 19 91.0° W
FDNY back then used to use a format called "ATIS". It sounds similar to MDC, but completely incompatable with it - it is a specific Motorola format. It was very short and was always in the begining of a transmission. It is only availiable in HT1000 & Visar radios.
Could it also may be MDC 600 I can't fi d any samples but people say there are some other radio series that can make the noise.
SimpleSkye
Northern California
MDC600 is much slower though and does not sound similar if I recall correctly. Plus, MDC600 will decode on a MDC1200 system. I know the Saber series did MDC600. At any rate, I know they used to use ATIS. As for MDC 600 or something off like GeStar I don't know. :)
Im at work right now so I cannot watch the YouTube clip until this evening. :(
gtaman
TACSAT
GALAXY 19 91.0° W
Alright I thank you I just curious so I posted it I haven't much info on it.
SimpleSkye
Northern California
I never really saw ATIS used much, MDC 1200 was way more popular - probably because more radios did it.
Try searching for ATIS on YouTube and see what you find. Just FYI, ATIS is also an acronym for a million other things like Automatic Terminal Information Service used in the area of airports, so your search may have tons of erroneous results. :)
At any rate, I'll check out the YouTube clip this evening and hit you back.
Gezelle007
Lurker in the Deep
Oregon
Thanks Matt
Old signalling!??? Old!!?? A city in my area just "upgraded" to mdc1200!!! Haha!!
Anyways, I have attached a zipped sound file that I have used as a text message ringtone before.
gtaman
TACSAT
GALAXY 19 91.0° W
That's the standard modern version. I want the one the FDNY used to use. Look a the YouTube link.
Gezelle007
Lurker in the Deep
Oregon
Ohh, I'm sorry, I only read through the first few posts, and that vid, that's not Motorola, that's Fleetsync- Kenwood's response to MDC1200. It sounds like this: http://www.w2sjw.com/sounds/FleetSync-Pre2.mp3 however the pre ident bursts are shorter I think.
gtaman
TACSAT
GALAXY 19 91.0° W
Nope that's what I thought but its not. At the time the FDNY only had Motorola and Vertex radios. And the city of New York does not use fleetsync.
Gezelle007
Lurker in the Deep
Oregon
Hmm that's weird. No idea what it would be besides those and GE bursts sound nothing like that. The only other id bursts I've heard were on trunking systems.
Kissimmee, FL
FDNY had the saber ll with MDC600 at the time of 9/11. The saber ll/lll both have mdc600/1200, you can change it through rss.
mancow
N.E. Kansas
That video appears to have the same ID after every transmission for some reason.
It sounds like MDC1200 to me.
