davidmc36
The threads are closed but never got any resolution to problems I posted. Isolation has got me digging out old projects.
forums.radioreference.com
If anybody pulls out an old 2067 and has trouble with squelch related anomalies, a different solution to any modification may help. I tried every imaginable value of squelch pots.
My trouble with randomly opening on the CC and pulsing display when in closed mode seems to have gone with a simple, adjustment.
Winchester Site has CC of 142.650. I re-loaded the system with it programmed as 142.600
So far, So good. Running for a couple hours.
Now if I can just figure out why the 396XT went deaf on the same system.............
PRO-2067 receiving problem
I have a mot type 2 system programmed and sometimes it receives loud and clear and sometimes it is all broken up. Any adjustments on the scanner to fix this. Thanks and happy holidays. Dave B.
Is there no way to scan MotoII with Pro 2067?
Never found any solution to this. Shows ID's 16 higher than actual in Open Mode. In Closed it shows correct ID but pulses. https://forums.radioreference.com/threads/pro-2067-pulsing-video.363284/#post-2857023 It also just opens squelch a lot on the CC. Squelch mod is installed. Any ideas?????
PRO 2067 Pulsing??-Video
What is the deal with this? MotoII System. WIN 92 File attached. https://www.youtube.com/watch?v=kKr4d1gNaZk
