Hi all,
I'm new to the hobby as an active participant but I've been around it with my dad pretty much entire life. So I've got to see a LOT of rig, but I need to define OLD when I say "old". Because for me an old radio is a vintage Helicrafters or an old Heathkit rig or even older than that (Keep in mind my dad was licensed right after his return home from the Korean war). When I say old, I really mean sometime before 2000 and after 1980 which gives us a 20 year window. Oddly enough (and I digress here) when I was younger I disliked anything old, but as I've grown up I developed a very keen fondness for the old rigs my dad had collected and really cherish them. There is nothing like that old tube glow in the middle of the night to remind you that this thing is really working, that something is going on. Plus when you're 6 the heater lights chase away closet monsters, lets be honest.
But getting a bit more modern, but still old enough. I've developed a fondness for older model digital rigs (no more knobs turning strings inside your Helicrafter rig). I'm talking rigs like the IC-730 or the IC-735 or the Kenwood TS440 (Dot problems aside). Lots of folks (especially new hams like myself) dismiss these older rigs, or if not dismiss them just flat out assume they're old and junky. Well that couldn't be further from the truth.
Sure sure, they don't have IF DSP (or any DSP for that matter) but some will argue that the receive and transmit of the AM in the IC-735 is second to none even today. You may have to have some outlay of cash once you get one (I did) to get it aligned, cleaned up and all ship shape. But that (at least for me) wasn't all that expensive at all ($70 or so). With a few modern gadgets, which in my opinion you might need/want even with modern rigs these radios will do a bang up job for you.
The one shortcoming you might have with the older rigs like these is pulling people out of the noise, and while in fact IF DSP is nice you can get away with Audio DSP for this too (with some AGC limitations). I shopped around for some sort of external audio processor and found the ideal match (made in heaven if you ask me) with the Elecraft AF1 Active Audio filter kit. This handy dandy little wonder can be put together (if you're experienced with soldering) in a few hours or so. What you get at the end of the day is a way to clean up CW and SSB signals like nobody's business. The beauty is two fold, one it's very inexpensive ($60 or so) and two it's Elecraft and they do some great things so you know you're getting a piece of quality gear. As an added bonus it's also an amp unit so all you need is a decent (and I suggest a fairly decent 3-5") external speaker for this and off you go with more audio control than you probably ever need. Sure this isn't DSP but it will surprise you and it won't cost you another $200 on top of everything else.
The next thing is digital modes, lets face it that digital modes are here to stay. But for our old radios that doesn't mean they're left out of the good times! Before I begin it's important to say that even new model radios, may require this investment as well. I found a fantastic way to get your old rig, for me that is an IC-735 on the air with digital is a small little device called the SignaLink by Tigertronic. There are other more costly brands that may or may not perform better but I've had great luck with this device and the IC-735. The cost for the SignaLink is nominal (about $85) and the cable and the jumper block will probably run you another $20ish (you don't *NEED* to buy the jumper block by the way, it's just an easy plug and play method). The advantage of using this device is that it offer complete isolation from your computer so you don't have to worry about RF. It's also it's own Soundcard so you only have one (1) cable going to your PC, and one going to rig. Of course if you're a CW user and want to use your PC as a keywer with something like Skimmer or CwGet you can obtain a WinKeyer they work with old rigs too.
The last thing you'll probably want is a good auto tuner, I have nothing against manual tuners at all. In fact I have a very nice Palstar roller inductor tuner that will do full legal limit. The reason I suggest an Auto tuner is simple, lots of modern transceivers have built in auto tuners. To this end there are LOTS of choice, my favorite is the LDG Electronics AT-100Pro II. There are lots of reasons I like it, it's compact and fits nicely and easily on top of the IC-735. It's not MFJ may be another reason to like it for some people. But most of all, it's fast and it manages to get 1:1 more often than not on any band you tune to. The cost is reasonable as well at about $215. This item also isn't necessarily one limited to only old school radios like the IC-735 since lots of the modern built in tuners can't tune complex loads or high impedance loads (like non-resonant vertical antennas). Before I get jumped on, I KNOW that relying on a tuner isn't ideal, ideally you'll want a resonant antenna that gives you low SWR without any fancy schmancy tuner. But the new guys (and the old) may not be able to come up with perfect antennas or what have you, making the auto tuner (or any tuner honestly) a handy piece of gear to have.
The last few things I have to say on this topic are this.. You can usually find these rigs relatively inexpensively in (usually) great condition. Usually you can find something like the IC-735 in the $200-400 range and often these will already have the WARC mods done. That's another thing, these radios have been out in the wild for a LONG time there's about a million mods for the IC-735 to improve it and even get it interfaced to your PC with RS-232 (I may be misremembering this one). To see just how well these old school 30 year old radios are, just go look at eHam, almost NO ONE has anything bad to say and for a radio 26+ yrs old or older that's really saying something. I'm sure (at least I hope so) that some of the Elmers and other will jump in and expand on the wonderful oldie radios and encourage other people that may be looking for a nice rig (starter or otherwise) to at least see there are some good choices out there. I still miss my tube heaters glowing in the dark in my room... *sigh*
