Dawn
I recently did two repairs on old RS power mics that took the infamous 7V battery. The board inside is the same that's found in cobra,sears,jcp, and hygain mics I've been in so far with some difference in components. Both of these were dead. I haven't seen problems in other vendors mics and the circuit differs slightly form manufacturer especially towards the later 70's.
I've found leakage in the electrolytics in some, but still not enough to affect the operation. In these mics, they used 2 sc536 transistors. They ohm out ok, but apparently have high leakage. Replacing both in one shot with an equivalent is a good option althogh it's the first transistor that's usually the cultprit. Most all early power mics made japan used this same circuit and board, and I suspect that Merry corporatation made them all for the companies. This must have been a common earlier failure. Several of the mics have been in essentially rewired to straight dynamic output and bypass the board. Another thing I've seen is without exception, the lower post that holds the switch is sheared off from stress, but usually doesn't affect the mic due to a case screw holding it together. Superglue solves this.
Shame. These were great mics of their day and probably today using a very high quality dynamic cartridge then found in today's mics with a very heavy duty cartridge typically found in japanese recording mics of the day. The RS mics had a particularly very nice ergonomic factor then their original mics or their competitors squarish form factor. The odd mic used in RS's TRC-46 and TRC-48 is essentially the same mic but wired as passive and the pot controlling the volume control.
The schematics published never seem to match the actual components of the mics and they usually show 2sc458 tranistors and the 'lytic cap values never match the what's in the mics I've been into.
If these mics were used with later Alkaline equivelent batteries, it's best to clean them with some vinegar. Your're never going to get a reliable contact without regular cleaning and cocntact enahancemt. It would be easy to replace the contacts or possibly dremmel them down and remove the chrome and use a nickle plating pen kit. I haven't tried that. Batteries are available on the net for less then $3 in alaline form.The original TR175 Mercury has been banned for years, but alkaline replacements works perfectly.
I've never ran across a dead turner board, but these seem pretty common in Japanese/Taiwan mics
I've been into.
I've been into.
