Open or search mode? Ok, I suppose that I could do that, but I will have to read how. I've not mastered that part of this radio yet. Thanks.
Ensnared,
I'm in Dallas, so not quite 100 miles north of you.
To scan the Oncor TSYS object in the equivalent to " ID search" mode (the term used in the Uniden scanners) or open mode (a term used for previous models of GRE manufactured scanners; GRE makes the Pro-197 for Radio Shack), just add a "group" wildcard" object.
In Win500, go to your Oncor TSYS object in your programming file.
Click in the 'status bar' just above the various talkgroups you already have entered. That makes the bottom "window" the active one for this next step.
Now, you can do this either one of two ways:
a. Create a new item by selecting the "Edit" menu at the to of the screen, then pick "New item at end"
or b. Use the keyboard shortcut <CTRL>+<Shft>+<N> (pressing the Control key, the Shift key, & the letter N, all at the same time).
That will create a new talkgroup object labeled as "Talkgroup" in the alpha tag, type will be group, and instead of a number, like the rest of the ones you have entered, the value in the 'Group or radio ID' column will be "Wildcard".
Having a group wildcard in the system will pick up any talkgroups that you do not already have entered. The scanner will stop on them and receive the transmission, and the talkgroup ID will be flashing on the display with an menu option present to store that ID to the radios memory. You could also set that wildcard ID, using Win500, to display a specific LED color to alert you of a new "find", or make the display backlight 'flash', or sound a beep, or a different alert, to catch your attention.
In case you're not familiar with it, an "easier to read" manual covering your scanner can be found
here. And here is a
reference for Win500, put together in large part, by a member who has since passed away.
