One GPS feeding two scanners
N9JIG
Sheriff
Moderator
Far NW Valley
Yep, works fine. I made a cable with multiple DB9's in parallel. I will look up the old posts and get the pinouts.
KC0YKO
Glenwood, IA
I may have found the pin out for programing
DB9
RXD=2
CTS=8
TXD=3
GND=5
4pin (front)
RXD=3
CTS=2
TXD=1
GND=4
N9JIG
Sheriff
Moderator
Far NW Valley
What I had done was take several BCT15/996 serial cables (with the female DB9) and cut the small end off and tied each of the 3 (or 4) wires together and then connect them to the corresponding wires from a male DB9 so I could use one Uniden GPS with multiple scanners.
In my original setup I was using a Garmin GPS-III to feed several scanners, an APRS rig and a laptop, again with a custom made cable. On that one I used an old-fashioned barrier strip so I could add and remove items as needed. This was back in the days when a Windows XP laptop running StreetAtlas was high-tech and GPS-SA hadn't yet been shut off.
