Eventually, I will have the ability/luxury to spend a lot of time scanning (and learning more about systems, etc.) I'm curious - can a single PC:
Mine currently is: i7 4650U / 2.3GHz / 8gb RAM / 64 bit / Windows 10
Is it able to run two scan apps (SDRSharp) with 4 dongles (1 antenna) at the same time - split to 2 separate monitors?
I'll only be listening to 130 MHz -175MHz (public safety and general aviation). As far as the database is telling me, there doesn't seem to be any trunked systems in the listenable area. Navajo County, Arizona (AZ) Scanner Frequencies and Radio Frequency Reference
Mostly I'm curious if it's one PC per app, or can one PC run multiple apps. When I try right now, it will not.
Thanks.
Thanks.
