DSDPlus One Radio with DSDPlus Fastlane
cpohlad
Midlothian, VA
So, I've been trying to get the one radio setup option working with DSDPlus Fastlane.
I edited my batch file for FMP24-CC to the following:
FMP24 -rc -i1 -o20001 -a1 -P0.0 -b12.5 -f855.6625
Here is what FMP24 looks like:
I am not getting any decodes though when I run the 1R batch file:
DSDPlus -r1 -T -E -Pwav -i20001 >>1R-log.txt
When I turn monitor on, I can hear the control channel in the application.
Thoughts?
Unitrunker works fine and decodes without issue.
cpohlad
Midlothian, VA
Nevermind, found the flag. What gain do you recommend? I am at 15 right now but still nothing.
R0am3r
Salt Water Conch
Oneida County, NY
You can also control the gain by clicking on the FMP24 window and then use the g/G keys while it is running. Gain depends on the signal strength. I typically don't exceed 30.
What type of signal are you trying to decode?
cg
Connecticut
I believe Unitrunker can trunktrack it with P25 decoding. Been a long time since I played with it though.
chris
radiotrack1
Lumberton, NC
What is the -a switch for in your fmp24cc file. Couldn't find that in the documentation. I dont use an offset or bandwidth switch. If you do not enter them the system will use defaults. My command lines are
FMP24 -rc -i1 -o2001 -f853.7875
DSDPlus -r1 -T -E -f1 -i2001
radiotrack1
Lumberton, NC
I couldn't edit my reply. Forgot to mention the -f1 in my 1r.bat is for P25 only. You should not have the -f1 for motorola smartzone
