One sided conversations
mszabo2000
Rootstown, Oh
If they use encryption, it's possible the dispatcher has disabled encryption on their end but the mobiles are responding encrypted.
jonsmth
Peru, MA
I have a Uniden 325p2, and I can hear the ambulance dispatcher but not the ambulance its self. I live in Pickaway County, any idea what the issue could be?
It seems that you may have the same situation that I have in the area I live in. The Fire/EMS dispatch is on one channel while the Fire/EMS response is on another channel. I looked at the Ohio MARCS-IP Project 25 Phase I trunking system; under Pickaway County it lists one talkgroup (39508) for Fire/EMS Dispatch and lists another talkgroup (39502) for Fire/EMS Response. I'm not sure whether the two separate channels are simulcast on non-trunked frequencies or not. In our situation where I live, the dispatch is broadcast on both the dispatch and response channels, so in most cases I still hear both sides of the conversation. I just ensure that neither channel has any delay programmed so that the scanner can immediately start scanning for the response.
lucky43113
Central Ohio/Pickaway County
That could be the issue ill check and see.
northernsummit
Macedonia, Ohio
Are you listening to a alert / tone out talk group? There are some alert / tone out talk groups that are used to initially dispatch. In Summit County I hear a couple of FD dispatches that go out like this:
1. Audio on the tone out / alert TG (presumably for pagers, station overhead paging, etc)
2. Audio "simulcast" on the actual Fire frequency the squad/engine radios are on.
The other thing you might be hearing is radio to radio calls?
lucky43113
It was the missing talk group I added it in and all seems fine now
lucky43113
That seemed to work Thanks
