The database list Turning Stone as DMR now. I have loaded it from the data base into my SDS200.Not having any luck receiving them, Is any one else? I use to but cannot now. It's listed as a DMR HYTERA XPT SYSTEM. Any help on this?
What type of system is it entered as? XPT does not use a control channel. I am not sure if it is supported on Uniden scanners. It may need to be programmed as one frequency DMR and scan all frequencies. Did you try to run "Analyze" on the system after you entered it to see if the SDS200 recognizes it.The database list Turning Stone as DMR now. I have loaded it from the data base into my SDS200.Not having any luck receiving them, Is any one else? I use to but cannot now. It's listed as a DMR HYTERA XPT SYSTEM. Any help on this?
That looks encouraging that the scanner recognizes it. Did the LCN # and system info Analyze displayed agree with what you had programmed?I did run analyse and it find one of three LCNS after running a few hours
Hytera XPT does not use LCNs. Try setting them all to 0 and see if that works. If yes, I will make the adjustment to the database.
Ok i did that and not getting anything now. Funny thing is while 3 frequencies are loaded, it stays on the first one. Not sure what I'm missingYou must have the system in a Favorites list before you can make changes to anything.
From reading other RR forum threads pertaining to XPT on scanners, it appears that others have had moderate success making each of the frequencies a single site (so three separate sites with one each of the frequencies in this case) rather than a cluster of the three frequencies on a single site.Ok i did that and not getting anything now. Funny thing is while 3 frequencies are loaded, it stays on the first one. Not sure what I'm missing
I’ll throw this out here. I discovered a XPT system here in North Carolina that exhibited similar behavior with the LCN. The analyze function would assign a LCN of 1 for different frequencies in the same site when I ran different analyze sessions. What I ended up doing was to create a separate site for each frequency. Instead of programming the system with a single 4 frequency site, I programmed it with 4 sites of one frequency each and assigned an LCN of 1 to each frequency. After that, it started tracking properly. I need to find another XPT system to see if it works the same way.
Yes the talk group ids are not correct. 100,133.I tried just programming the frequencies in as conventional. They come in but there is a data burst before the voice.From reading other RR forum threads pertaining to XPT on scanners, it appears that others have had moderate success making each of the frequencies a single site (so three separate sites with one each of the frequencies in this case) rather than a cluster of the three frequencies on a single site.
Give that a try. Also, the Talkgroups reported here according to the forums are in decimal format from a Whistler scanner. The SDS's will put them in a different format. For instance, TSC Security on an SDS is TG 100. Hope these help.
The talkgrouo ID’s are correct for a Whistler, they’re just a different format in the SDS. I would suggest you take the programming advice on the multi-single site programming as trunking. I think you’ll find much better results than conventional programming.Yes the talk group ids are not correct. 100,133.I tried just programming the frequencies in as conventional. They come in but there is a data burst before the voice.
So are you saying to create 3 separate trunk systems?The talkgrouo ID’s are correct for a Whistler, they’re just a different format in the SDS. I would suggest you take the programming advice on the multi-single site programming as trunking. I think you’ll find much better results than conventional programming.
Create one trunk system with three sites, one frequency for each with Site ID 1. So Site 1 = 454.1125, Site 2 = 454.3125 and Site 3 = 454.5125So are you saying to create 3 separate trunk systems?
That would be quite inefficient. Using OFT would be the way to go, as it will scan all three frequencies in one shot, and you only have to maintain one set of talkgroups, etc.Create one trunk system with three sites, one frequency for each with Site ID 1. So Site 1 = 454.1125, Site 2 = 454.3125 and Site 3 = 454.5125
DMR One Frequency TrunkedOFT?
Enter the system as "DMR One Frequency" but with 3 frequencies as I had suggested in my early response to you. This is the procedure you normally use for a DMR single frequency system with multiple TGs.
