scanner_freak said:Let me help you. Please listen, because you are confused.
262 is the system ID
101 and 102 are site numbers for that system. It is one system, 2 sites. I suspect there will eventually be a 103 and 104 etc...Some sites operating alone, some simulcasting.
THEN, there will be ANOTHER system with a different system ID. It could be 261 or 263, (that would make sense). Then, they will also have 101, 102, 103 etc..
Now, example, 101 could be 4 sites simulcasting as one and 102 could be a single site all within the same system.
Viper43 said:Not sure if this will the other system ID or not but this popped up for about a minute this morning 5f50 then it vanished. It was on one of the channels being tested so who knows.
Also Pro96Com is showing DATA CHANNEL UPDATE: 40 Channels
V
On a BCD396t, holding on an active Control Channel shows first, System ID in Hex, then Tower or site id 0101.w8fcc said:5F50 is a tower ID look back a page and see my Example you should see this
262H-101 then when a ID pops up pending on witch tower they are hiting in on you will see a ID like 5f50 by the way they only have a few up and running at 21st and post is the main one right now and yes it is on the ISP tower they where talking about that yesterday on there.
Take your 396T and hold on MECA SYS 1 CC watch it it will show 2723 then when a ID pops up pending on the tower it will show you 5e30F or 21f0E pending on the tower. You will have to watch a while dont give up right away some times it takes a while for the scanner to see it. I hope that helps
Those seem to be group ID's rather than System ID, at least that's what I get when I convert from Hex to Dec.w8fcc said:On SYS 1 analog this is what shows up as far as System ID
2723H
5dd0H
2bd0H
21F0H
5ef0H
4ef05
5e3foh
and so On the same on the new P25 when it is active it shows in place of 262-101 pending on the tower it will change but they dont have a lot of the towers on yet the other numbers are the tower site
newsalan said:Those seem to be group ID's rather than System ID, at least that's what I get when I convert from Hex to Dec.
Well, I get a five digit number when I convert... and each of the other one for the message I responded to also convert to five digits. Ergo, talkgroup ID's and I though we were talking about the new digital system. That’s what I was talking about and that’s what this thread is about. The new 9.6 digital system.Viper43 said:2723 is the system ID of system 1 (old analog system), which you should know since A: it's listed in the databse info B: you claim you monitor the system.
Old system 2 (analog) is 3A3A
V
W9NES said:ScannerFreak,Again i will ASK YOU TO CLOSE THIS THREAD. This is GETTING VERY OLD AND NEEDS TO STOP. PEOPLE ARE JUST PUTTING DOWN EACH OTHER AND THIS IS A "Hobby" Not a place to ''PUT OTHERS DOWN"
I for one am looking forward to the information.fire4456 said:Hello all I just want to say that we are currently getting our radios changed into a new template here at work. This template is kind of a mess due to it having the analog digital state and failsafe all programmed into it. I will work on getting a copy of the template out to a moderator to post so when this system goes online you can id the talkgroups. This will be a huge change from what has been done before. I want to calrify that this IS NOT smoking mirror stuff nor is it rumor. I am a user on this system and a active firefighter paramedic for wayne twp. fire. So once every 3 days I use the system and we have been told of the changes and what it will mean. The new digital system will do away with individual talkgroups( ie ops 81, ops 11, and so on). There will be like something from ops 1 to ops 18 or something. The analog template will stay in the radio should the digital system fail we have a fallback. We also will be getting a new firehouse alerting system come later this year. We are told this will be a digitized voice at the firehouse and that this is supposed to be better and MECA can put out more than one run at the same time instead of having to wait to dispatch the run they are announcing at that time. So I ask a little patience in this matter as I will get it submitted to the moderators for posting. Thanks all for who have submitted replies and posts. Have a good day and be safe.
