newsalan said:900MHz ? Are you meaning 800MHz, and I’m sure approval will come, it may take some congressional intervention or pushing, but if the need is there… it will come. I’m thinking the FCC/coordinator is thinking why not just use what they have, especially when it is re-banded. I don’t think they will get approval for two new P25 systems and at the same time keep two old analog systems on the air for mostly backup.
w8fcc said:By the way who is on 700 in INDY the only lic is ISP and they are not using it and yes the Feb 2009 has a lot to do with it That is the whole deal with AnalogTV shutting down and moving bands and going Digital to make room for Public Safty to use. I scan the 700 band all the time and no one in public safty is on there.
Also both SYS 1 and SYS 2 have to be the same SYS2 is the back up for 1
Viper43 said:No, I meant what I said.... the original plan was to use 900Mhz, however they were told the coordinator wouldn't approve that, that was before ordering the present radios so they went to the next plan which was 700Mhz. The idea was to keep System 2 800Mhz and then have system 1 700Mhz.
They do not have to wait until Feb of 09 as stated by W8FCC, the coordinator can work around the few 700Mhz frequencies in use now in the Indy area, thats there job, and why getting approval is taking so long.
V
w8fcc said:Again who in INDY AREA is using 700 I did not say Ohio I was talking IN
All states and Public Safty has to go through the 700Mhz Plublic Safty Regional Planning Committee to get approval for 700Mhz and yes some states are using it because they got approved IN has not got it yet they only one is ISP WPTZ 769 Just a block of freqs nothing set up yet No tunked Systems and it is you who needs to check you info here is a basic link that will get you started on how Analog TV shut down does have somthing to do with it
http://www.dtv.gov/whatisdtv.html
http://www.dtv.gov/index.html
Converting to DTV also will free up parts of the scarce and valuable broadcast spectrum. Those portions of the spectrum can then be used for other important services, such as public and safety services (police and fire departments, emergency rescue), and advanced wireless services.
V
This is pretty bizarre... I don't believe Public safety has ever had an allocation at 900 MHz, so of course APCO couldn't coordinate 900 MHz channels. But if MECA had really intended to license 900 MHz, they could have gone to one of the coordinators certified to do 900 MHz to try to get it done. There are a number of frequency coordinators who are willing to take just about anybody's money to do coordination and there is no rule that public safety agencies must use APCO for coordination. Perhaps MECA tried to pull APCO in to help them broker an arrangement with another coordinator and APCO wouldn't help out... So at that point MECA shifted to 700 MHz rather than go it alone with a non-PS coordinator.Viper43 said:No, I meant what I said.... the original plan was to use 900Mhz, however they were told the coordinator wouldn't approve that, that was before ordering the present radios so they went to the next plan which was 700Mhz.
V
w8fcc said:Look at what you saide "few 700Mhz frequencies in use now in the Indy area"
what is IN USE IN INDY?
delallen said:Guys - Chill Out!
