ugh - Just picked a talk group - didn't see the #
ENCRYPTED!
Heard it then flashed on my 796D
I'll try to catch it.
How far are you from the nearest MECA tower and how high above ground are your antennas?
Those of you using the GRE or Uniden are you capable of having a closed bank on the new Indy P25 system? By a closed bank that would be having select talk groups in a bank and listen to just those programmed groups. I have the Pro 96 that I have to keep the bank open in order to receive anything and not being able to narrow down just the few groups I would like to monitor.
My only option I have now is to leave the bank open then select the lockout for the groups I don't want to listen to.This list will quickly fill up as the new system expands and the Pro 96 runs out of memory allocation. Anyone else with the Pro 96 or 2096 have this issue? Any work arounds?
Are you using the 796D or any other scanner?
The 796D has no fixes and is out dated it will not work very well with the new types of P25 digital I would trade it in for a 996 or 396 or GRE or even a new radio shack 2096
GTO - you may have missed it before, but location is CRITICAL.
It doesn't take much to see that some people lucked out by having their homes in a perfect spot. But don't equate that to others having the wrong radio, or programming it wrong, or anything else. This is a KNOWN issue which affects E V E R Y CQPSK simulcast digital system in the COUNTRY. A directional antenna pointed at the closest tower is how you get the best signal. Nothing else.
