ONLY SCAN CERTAIN FREQ. BAOFENG UV-82HP?
Tdub779
I AM TRYNG TO SET UP A RANGE OF FREQ.'s THAT MY RADIO WILL SCAN AND CANNOT FIND THE INSTRUCTIONS ON THE NET.
Thanks in advance.
The radio is NOT a scanner, it is a low budget transmitter. It will only scan the given analog frequencies that you program into it. Be careful with the programming though so you do not accidentally transmit on any freqs you've programmed in to scan.
