OnQue NXDN
IdleMonitor
The Ottawa Valley - Eastern Ontario
So..I've finally heard my first comms on this system. Is it just like other systems how talkgroups follow the towers?
Oddly enough the other night I heard Herbs Towing (Cornwall) on both the Pembroke and Renfrew sites. Odd I thought other then their was a unit in the area to affiliate with those sites.
The NXDN aliases on the RID's were working fine as well. A very nice feature by the way.
Anyhow. Like I said this is my first comms to hear atleast in this area. (Heard activity a few weeks ago when I went to S Ont.) & was nice to finally get.
I just wish there was more activity on these site. I'd Imagine Ottawa area has more activity I'm just never there to listen to find out.
AOD999
Etobicoke, ON
I've always had trouble with this system on my TRX-1.
VA3SOM
Ontario, Canada
OnQue has been a hard one to scan for me on my TRX-1 and 2 only TG i really ever hear is HARP.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Using a BCD 536HP has been great on OnQue. I've only entered the CN Tower site and it is quite busy. Mostly on the Multi-Site and Toronto categories.
The radio ID shows up first, then switches to Alias, which is nice to confirm users. But, I have to manually name the talkgroups or leave them as digits,as at this time there is no Sentinel import.
VA3DBJ
Ontario Database Admin
I programmed the network in Sentinel, as a P25 Motorola system, as a favorite by itself, with all the groups and such. Up loaded the favorite to the scanner and before pulling the cable, for the reboot, I opened the file in the FavoriteLists folder on the scanner with notepad. Changed the "Motorola", on the first line, to "Nxdn" then save the file, then pulled the cable and let it reboot.
To: Trunk OnQ Network Off Nxdn
Keep in mind that the file is tab formatted. So only change the word Motorola.
Being in a separate favorite, you can make changes in your regular favorites, and your NexEdge favorite won't get over written. When you do make changes, just remember changing the system type, before you let it reboot.
DaveH
Ottawa, Ont.
A bit off the topic but wonder if somebody closer to Cornwall could confirm that 423.3625 and/or 423.6625 are active on this system, and the site number. I heard a bit yesterday on one, but barely enough to indicate DMR.
TAFL Search Results
Dave
