Curious - that's definitely different than the usual pcm underruns. Sample rate sounds wrong, not that you usually have control over that.
Questions:-
- which version of op25 are you using? (osmocom or boatbod)
- are you using the built-in audio server (-U) or netcat | aplay
- is there anything else running on the host machine?
A copy of the stderr.2 log might provide some insight, along with a screen capture of "top -H" when there is audio playing.
I'm using osmocom and the built in audio server. Also, nothing else running, though I am connecting via RealVNC. Not sure if that would have any impact. Overall resource use is pretty low when OP25 is running. CPU @ 17% and Mem is 203 of 927.
I apologize, but I'm not sure what the "top -H" is.
Below is a copy of stderr.2:
gr-osmosdr 0.1.4 (0.1.4) gnuradio 3.7.10
built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri hackrf bladerf rfspace airspy soapy redpitaya
Using device #0 Realtek RTL2838UHIDIR SN: 00000002
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
Using two-stage decimator for speed=960000, decim=10/4 if1=96000 if2=24000
Project 25 IMBE Encoder/Decoder Fixed-Point implementation
Developed by Pavel Yazev E-mail:
pyazev@gmail.com
Version 1.0 (c) Copyright 2009
This program comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to redistribute it
under certain conditions; see the file ``LICENSE'' for details.
op25_audio:
pen_socket(): enabled udp host(127.0.0.1), wireshark(23456), audio(23456)
p25_frame_assembler_impl: do_imbe[1], do_output[0], do_audio_output[1], do_phase2_tdma[0], do_nocrypt[0]
audio device: default
