OP25 (boatbod) -> Liquid Soap -> Ice Cast: Very high latency
xtraorange
Hello all-
I was able to successfully setup my RTL-SDR Blog v4 on a VM (hosted by proxmox on my small server cluster), feeding through liquidsoap to IceCast on another VM using docker. Resource wise nothing is pegging, so I don't think I'm choking anything.
Everything is working well now, except that I cannot seem to squash down the latency. It's running pretty consistantly around 30 seconds delay from the live broadcast.
I am 100% new to this, so I'm not sure what to expect here. I'm hoping for a near-live (within a second or two?) performance, but is that unrealistic? Because it's running from a VM, I've been having a hard time determining where the delay originates (since I can't listen to it live) before it's fed through the pipeline. I've done a fair amount of searching and experimenting with settings on liquidsoap and icecast, but I'm wondering if the problem is originating in OP25.
I can post configs or whatever else would be helpful - would love any wisdom you can provide here, even if it's just to reduce my expectations.
wgbecks
NE Wisconsin
The approximate 30 second delay is inherent in the design of the Icecast server. You may be able to shave off a few seconds by disabling
burst-on-connect, but it's probably not worthwhile. You'll have to explore other technology options if it's your intent to reduce latency
to a minimum.
