The most obvious error is that "-args" requires two dashes like this --args
Second thing is you probably want to reduce the sample size as 2.4Mhz is at the upper limit of an RTL capability. Suggest "-S 1440000" for most desktop machines. If it's a RPi3 you'll want "-S 100000" or so.
Third thing, you probably don't need "-o 25000" unless you have an old dongle with a DC-spike.
Fourth thing, you've got no trunk.tsv defined so op25 isn't going to trunk track as currently configured. If the -f refers to a control channel then the terminal should start to receive TSBKs when it runs, but that's about it.
Thank you........yes the --args corrected my issue. I have it decoding audio just fine to the speaker output and it sounds great again. I will try removing the things that you think I don't need and adjusting the sample size and see how that goes. I did not have my trunk.tsv defined the other day but I had since done all of that along with my talkgroups and whitelist files. It is working now. My next steps will be to get the scripts set up so that it all starts on boot and get the streaming working with Liquid Soap. I would like to continue to be able to output the audio to the speaker as well as streaming. I will work on that beginning tomorrow.
