OP25 "boatbod" Talkgroup.tsv Errors
rcummings14
clarksburg wv
When I add my TG.tsv file the trunk.tsv I get a bunch of errors. Everything works fine when I don't have the .tsv file in trunk.tsv. I'm a noob to linux.
gr-osmosdr 0.2.0.0 (0.2.0) gnuradio 3.10.1.1
built-in source types: file fcd rtl rtl_tcp uhd hackrf bladerf rfspace airspy airspyhf soapy redpitaya freesrp
Using device #0 Realtek RTL2838UHIDIR SN: Tuner1
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
Exact sample rate is: 2500000.107620 Hz
__set_rx_from_osmosdr(): failed to set frequency
Using two-stage decimator for speed=2500000, decim=25/4 if1=100000 if2=25000
Project 25 IMBE Encoder/Decoder Fixed-Point implementation
Developed by Pavel Yazev E-mail: pyazev@gmail.com
Version 1.0 (c) Copyright 2009
This program comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to redistribute it
under certain conditions; see the file ``LICENSE'' for details.
op25_audio::eek:pen_socket(): enabled udp host(127.0.0.1), wireshark(23456), audio(23456)
p25_frame_assembler_impl: do_imbe[1], do_output[0], do_audio_output[1], do_phase2_tdma[1]
Traceback (most recent call last):
File "/media/ray/DATA/op25/op25/gr-op25_repeater/apps/./rx.py", line 910, in <module>
rx = rx_main()
File "/media/ray/DATA/op25/op25/gr-op25_repeater/apps/./rx.py", line 833, in __init__
self.tb = p25_rx_block(self.options)
File "/media/ray/DATA/op25/op25/gr-op25_repeater/apps/./rx.py", line 235, in __init__
self.open_usrp()
File "/media/ray/DATA/op25/op25/gr-op25_repeater/apps/./rx.py", line 717, in open_usrp
self.__set_rx_from_osmosdr()
File "/media/ray/DATA/op25/op25/gr-op25_repeater/apps/./rx.py", line 658, in __set_rx_from_osmosdr
self.__build_graph(self.src, capture_rate)
File "/media/ray/DATA/op25/op25/gr-op25_repeater/apps/./rx.py", line 364, in __build_graph
self.trunk_rx = trunking.rx_ctl(frequency_set = self.change_freq, debug = self.options.verbosity, conf_file = self.options.trunk_conf_file, logfile_workers=logfile_workers, send_event=self.send_event)
File "/media/ray/DATA/op25/op25/gr-op25_repeater/apps/trunking.py", line 1183, in __init__
self.build_config_tsv(conf_file)
File "/media/ray/DATA/op25/op25/gr-op25_repeater/apps/trunking.py", line 1252, in build_config_tsv
self.setup_config(load_tsv(tsv_filename))
File "/media/ray/DATA/op25/op25/gr-op25_repeater/apps/trunking.py", line 1313, in setup_config
self.configs = make_config(configs)
File "/media/ray/DATA/op25/op25/gr-op25_repeater/apps/tsvfile.py", line 177, in make_config
read_tags_file(tgid_tags_file, result_config[nac]['tgid_map'])
File "/media/ray/DATA/op25/op25/gr-op25_repeater/apps/tsvfile.py", line 141, in read_tags_file
txt = row[1]
IndexError: list index out of range
maus92
The OP
Can you attach both your tg.tsv and trunk.tsv files? You will probably need to change the file extensions from .tsv to .txt
rcummings14
clarksburg wv
As I was getting ready to send the files. I took one last look and realized I had a comma separating one of the rows. I appreciate your help though.
