OP25 Boatbod TG priority
jschmall
Anderson, CA
I have a question regarding the priority numbering for TG's. How granular can the numbering be? Does the numbering system have to be 1, 2, 3, 4, etc or can it be 1.1, 1.2, 1.3, 2.0, 2.1, 2.2, etc.. I'm hoping to create sub-levels of priorities within blocks of TG's.
I notice that when I specify numbers with decimals, all talkgroups assume a priority of (3) in stderr.2.
boatbod
Talbot Co, MD
Does this help?
Code:
                    if len(row) >= 3:
                        try:
                            prio = int(row[2])
                        except ValueError as ex:
                            prio = TGID_DEFAULT_PRIO
                    else:
So as you can see, the priority has to be an integer, but there is no limit on the range, so you could use negative numbers, set a priority value on every tgid, or change the default value. (The latter would require editing the tk_p25.py module, so probably less desirable).
jschmall
Anderson, CA
Does this help?
Code:
                    if len(row) >= 3:
                        try:
                            prio = int(row[2])
                    else:
Ok that makes sense. I will move from decimals to whole values. Doesn’t really matter how I do it in the end as every TG will have a priority set. Thanks boatbod.
